Ugly Nasty crack - Printable Version
+--- Forum: MECHANIC RECOMMENDATIONS (https://968forums.com/forum/mechanic-recommendations)
+--- Thread: Ugly Nasty crack (/ugly-nasty-crack.html)
Ugly Nasty crack - Carl968 - 04-29-2009
    Anybody run into this problem ever??
While trying to adjust spacing around my '92, 968 coupes' hood I discovered this nasty crack where the hood hinge attaches to the hood itself.
I do not know how it happened or when. I've owned the car since 2/2004 and never noticed the crack before. Maybe previous owner damage that was repaired incorrectly, just do not know.
I live in SE Massachusetts in Medway, MA and am looking for someone with knowledge of a body shop to handle this repair?
I have been in contact with my local Porsche club and I've had the work estimated at Prime Porsche in Westwood/West Roxbury, MA.
Do not want to drive it any distance because it seems to make the damage larger so any help finding a local repair guy would be helpful.
Carl
Ugly Nasty crack - xrad - 04-30-2009
hmmmmmm....
look for corresponding injury (where it touches when closed)
or maybe old front end accident buckled the hood
unusual spot...
Ugly Nasty crack - banditsc - 04-30-2009
Use a good magnet to search for bondo on the hood.
Ugly Nasty crack - Carl968 - 04-30-2009
<!--quoteo(post=71078:date=Apr 30 2009, 12:09 PM:name=banditsc)-->QUOTE (banditsc @ Apr 30 2009, 12:09 PM) <{POST_SNAPBACK}><!--quotec-->Use a good magnet to search for bondo on the hood.<!--QuoteEnd--><!--QuoteEEnd-->
The body shop that I took it to today seems to think that it is fatigue or an age type failure. A small area for a small hood hinge and a small pivot area for a large , long and relatively heavy hood. Will have to repair and weld the spot and then reinstall and realign the hood. Paint as well.
Ugly Nasty crack - flash - 04-30-2009
looks to me like the hood was kinked and straightened and then it cracked there
Ugly Nasty crack - Anchorman - 04-30-2009
...or you've had a hood hinge that's been binding, transferring stress to the sheet metal.
Ugly Nasty crack - S_Cal968 - 04-30-2009
Ouch, looks like a stress fracture. That may be a tough repair. I doubt it can be welded; from what I've seen it'll re-fracture along the edge of the weld. Perhaps it can be trussed, but getting a good bite with the fasteners may be a challenge.
Ugly Nasty crack - Carl968 - 05-01-2009
Thanks I appreciate the input guys. Not sure at this point what is next. Still have more people to talk with.
Ugly Nasty crack - biotechee - 05-01-2009
Used hood from Ebay or a dismantler. Then get it repainted if necessary. Depending on where you are located with respect to a used one, shipping might or might not be an issue.
Ugly Nasty crack - flash - 05-01-2009
if you repaint a hood, make sure to either mask the emissions stickers or get new ones if you are in a state that requires them (like california)
<!--quoteo(post=71159:date=May 1 2009, 09:08 AM:name=flash)-->QUOTE (flash @ May 1 2009, 09:08 AM) <{POST_SNAPBACK}><!--quotec-->if you repaint a hood, make sure to either mask the emissions stickers or get new ones if you are in a state that requires them (like california)<!--QuoteEnd--><!--QuoteEEnd-->
Thanks Flash, I had already decided that all of the stickers would be removed or masked as you said.
