Where are the bolts holding the rear storage located in a Cab? -
caffine - 04-30-2009
I've searched high & low on this website & the manuals for the bolts holding down the rear storage in a Cab.
I see what looks like plastic trim covering a bolts head just inside (& too the exterior side) of the storage bins
Before I start mangling things up I wanted to hear from the experts if these are indeed the mounting bolts. Are there any other locations? Thanks.
flash - 04-30-2009
there are 2 bolts, one on each side that go into the wheel hump
there are also 4 nuts way in the back on the rear wall that attach two small brackets - they are tiny (8mm i think) and a royal pain to get to
biotechee - 05-01-2009
I just took out the cubby doohickey in my cab- the big bolt on each side was there, but I only had one nut on the back underside of each cubby. When I got the whole thing out, I only have one body tab on each side. So, a total of two bolts and two nuts.
If you think the nuts in the back are hrd to get to, try getting to the one if you have the optional CD changer!! Serious OUCH!
caffine - 05-01-2009
<!--quoteo(post=71140:date=Apr 30 2009, 09:08 PM:name=flash)-->QUOTE (flash @ Apr 30 2009, 09:08 PM)
<{POST_SNAPBACK}><!--quotec-->there are 2 bolts, one on each side that go into the wheel hump
there are also 4 nuts way in the back on the rear wall that attach two small brackets - they are tiny (8mm i think) and a royal pain to get to<!--QuoteEnd--><!--QuoteEEnd-->
So everything is accessed from within the storage boxes. Will give it a go tonight.
caffine - 05-02-2009
[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] Yeah. Too easy - the difficult to get to nuts were only finger tight so I just used my fingers and it was out in a few minutes. Thanks
