headlights - Printable Version
+---- Thread: headlights (/headlights--9552.html)
headlights - daly - 05-09-2009
I don't see any info on DIY on headlight aiming. Just had some work done and they did not do it. One is aimed up to the sky the other to the ground.
Anyone have a thread or a place tpo go to show how to do it?
headlights - flash - 05-09-2009
the procedure is in the workshop manual
headlights - Kim - 05-09-2009
Be careful if you have to remove the trim rings around the lights to pre-lubricate the aiming mechanisms prior to aiming. They crack easily.
headlights - 968Syncro - 05-10-2009
This procedure has gone around often as a valid way: http://www.danielsternlighting.com/tech/aim/aim.html. Internet search on "headlight aiming" will show other published ways for DIY.
Roland
