windshield washer nozzle -
SILVY968 - 07-30-2009
I have noticed that the driver's side windshield washer nozzle is squirting out washer fluid when I hit a bump in the road.
The fluid is leaving its trail on the hood between the nozzle and the windshield. Some squirts are strong enough to make it to the windshield.
The passenger side is fine.
Is there a valve in the nozzle that keeps this from happening unless you pump out the fluid?
Anyone ever run into this wet issue?
Mark - 07-30-2009
Happens on one of mine hvae not investigated it yet
Anchorman - 07-30-2009
Ditto.
biotechee - 07-30-2009
Look at PET illustration 904-10 (I looked in MY94, but it is probably the same illustration for all years). From the illustration, there is a valve upstream of each nozzle, see items #18 and #19 in the diagram. Perhaps this valve (for your side) is shot. There aren't any other valves / controlling devices in the system that I can see....
Each valve looks to be under $10.
flash - 07-30-2009
there is a valve for each sprayer - it's a check valve - mine used to do that until i changed them
SILVY968 - 07-31-2009
Thanks all!
914-628-215-00-M78
Check Valve for Windshield Washer Pump, Straight Brand: SWF
ordered.
Great site!
rhudeboye - 07-31-2009
Is the set up for the window washers the same on Cabs and Coupes? Seems that only Cab owners are chiming in on this one.
banditsc - 07-31-2009
Mine does that also, Cab, always wondered about that..
SILVY968 - 08-01-2009
<!--quoteo(post=76521:date=Jul 31 2009, 05:50 AM:name=rhudeboye)-->QUOTE (rhudeboye @ Jul 31 2009, 05:50 AM)
<{POST_SNAPBACK}><!--quotec-->Is the set up for the window washers the same on Cabs and Coupes? Seems that only Cab owners are chiming in on this one.<!--QuoteEnd--><!--QuoteEEnd-->
I think that it must be that most of the time, that cabs travel at a much higher speed than the coups, and that the constant acceleration forward causes the water to damage the valve.
rhudeboye - 08-01-2009
<!--quoteo(post=76590:date=Jul 31 2009, 10:18 PM:name=SILVY968)-->QUOTE (SILVY968 @ Jul 31 2009, 10:18 PM)
<{POST_SNAPBACK}><!--quotec-->I think that it must be that most of the time, that cabs travel at a much higher speed than the coups, and that the constant acceleration forward causes the water to damage the valve.
Brian<!--QuoteEnd--><!--QuoteEEnd-->
[img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] You Wish Brian.
rslyper - 08-10-2009
Both mine do that when I pull the wrong stalk forward to release the cruise!
rxter - 08-10-2009
One of the few 'cab only' problems I don't seem to have. I never use the things anyway cause the wife is not fond of the squirter bath.
easy dan...
flash - 08-10-2009
of course now having said that you have tempted the porsche gods and will now have your reservoir develop a leak requiring removal of the right wing to repair
bva - 08-10-2009
had the same problem with my driver's side also; ordered the check valve last month; problem went away before i installed it; easiest fix i've made yet.
maybe the reservoir is empty...
SILVY968 - 08-12-2009
5 minute fix.
I must say that this may have been the fastest and least expensive fix I have done since I got her.
Not a big deal, but nice not to have spots and drips on the car.
