fuel smell after high-g cornering.... -
chazie78 - 06-18-2019
Title says it all..... strong fuel smell after very hard cornering. what would you check first?
94SilverCab - 06-18-2019
Fuel Filler Neck is known to crack, see this thread.
http://www.968forums.com/topic/11418-gas-smell-in-cabin/#entry149079
Regards,
pdxmike - 06-18-2019
First would be a visual and "sniff" test under the car to make sure there are no obvious fuel leaks. Absolutely check to make sure your fuel lines leading into the engine compartment are intact.
Second - check that the fuel cap is seated and that the gasket is good.
Third - check if you have any vapors escaping from fuel level sender access under the pass side rear carpet
Fourth - possible that your hatch seal is worn and enriched exhaust is finding its way into the cabin. If it is worse with windows down this may be your issue as you are creating a vacuum pulling the exhaust into the cabin.
Finally - as noted by Jay above - and this seems more probable if the issue is only with cornering - you might have a break where the fuel filler neck meets the tank. Apparently a well documented issue in the 944.
community. Would also expect it to be more of an issue with full tank as opposed to running low...
Right on guys... I don't see or smell anything near the lines, or vapors near the sender. I had a nearly full tank and this was during the hardest cornering I've done so far. I will check the neck!
ds968 - 06-18-2019
Quote:I had a nearly full tank and this was during the hardest cornering I've done so far.
Slightly off the main topic, but hard cornering should be done with a nearly empty gas tank ..no more than 1/8 tank. Very noticeable and quite a big difference in handling / turning without the added weight of a full tank .
Rap - 06-19-2019
Don’t drive with a full tank.
chazie78 - 06-19-2019
yeah, i rarely fill it up, but no hard cornering with a partial tank? c'mon.....
Rap - 06-20-2019
My one 968 has had a fuel smell that I’ve repeatedly had checked to no avail. My track car obviously does hard cornering and braking and doesn’t.
