Koni Shock Adjustment - Printable Version
+--- Forum: REV IT UP (
https://968forums.com/forum/rev-it-up)
+---- Forum: Handling and Suspension (
https://968forums.com/forum/handling-and-suspension)
+---- Thread: Koni Shock Adjustment (
/koni-shock-adjustment.html)
968forums - 03-25-2010
Koni Shock Adjustment Instructions
mdss - 12-06-2011
One question relating to this. I was adjusting my koni sports as per flash's recommendations and i wound them fully hard first by accident but noticed that when fully hard the shock would not rebound from fully depressed it stayed shut and finally rebounded after nearly 20 minutes...yes it was that slow.
My question is do i have a problem with my rears or is this normal?
I then set them half a turn from soft as flash suggested and they rebounded normallly.
Thanks guys
flash - 12-06-2011
might just be a sticky valve at the limit
