seat belt buckle - Printable Version
+---- Thread: seat belt buckle (/seat-belt-buckle.html)
seat belt buckle - apex - 06-16-2010
The passenger seat belt buckle - the black plastic clamshell part surrounding the buckly, snappy part has let loose at the seam. I epoxied it back together but the glue didn't hold.
Has anyone successfully put one of these back together?
seat belt buckle - DaveN - 06-16-2010
If it's ABS or PVC you can use the glue from the hardware store as it actually melts and bonds the plastic. I imagine it might not be either though as usually these incarnations are quite hard and that cowling is soft n'est pas?
Dave - thanks for the follow-up - not ABS or PVC - it is indeed something harder than those. But you're right: there's probably an adhesive more chemically suited than the epoxy I tried.
seat belt buckle - DaveN - 06-17-2010
We have a chain here in Canada called Industrial Plastics who handles all types of plastics and cements for these purposes, you must have and equivalent in the US?
http://www.ippnet.com/home.html
I couldn't find a 1-800 on their web site otherwise you could just call and pick their brains.
seat belt buckle - apex - 06-20-2010
DaveN, thanks for your reply! I did find an 800-number on the site you mentioned - all western canada. But I like your idea of consulting a plastics expert. If I can't find someone to call in the SE USA I'll call our friends in Canada and get some advice.
seat belt buckle - apex - 07-30-2010
Following-up: Purchased some 3M super-glue and the clamshell is holding fine.
That's the good news.
The bad news:
The mechanism failed inside. Won't go into the details but the short story is I just called Sunset to learn that the little 12" replacement belt and buckle can be had cheap for $203.50. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Anyone have a spare passenger side buckle? Or know if this is a generic part available from a non-Porsche souce? (Hat's off the the "alternate sourcing" thread!!) If no reply here I'll try Parts Heaven or another used source.
Cheers, and thanks.
seat belt buckle - Monstrous4Banger - 07-30-2010
I got one from a 944 turbo. Pretty sure its the same part, Ill have to double check.
seat belt buckle - Monstrous4Banger - 07-31-2010
Yep, theyre the same OEM part. Pm me if your interested. Ill beat any ones price, I need the space in the garage, and the 944 stuff has got to go.
