Oil pump housing leak -
earossi - 03-04-2011
As a few of you know, I am attempting to fix all the oil leaks on my motor. I now have all the belts and belt housings off the front of the engine needed to work on a lower balance shaft leak. I noticed that I have a small "weeper" around a few of the bolts that attach the oil pump housing to the front of the engine. Can I remove the pump housing from the engine to renew the gasket seal of the pump housing WITHOUT disturbing the attachment of anything internal to the housing (like the oil pickup tube)? If the housing comes right off, it will be very easy to fix the leaker.
Cloud9...68 - 03-04-2011
This isn't a direct answer to your question, and don't get me wrong - I'm not recommending that you do this, because it's a HUGE job, but since I've removed the engine from my car (primarily because I'd like to upgrade the connecting rods in preparation for heavy track use and possibly forced induction in the near future), I've found sources of leaks I hadn't suspected before. For example, the o-ring material that mates the oil filter housing (not sure of the technical name for it) to the engine was shot. And the o-rings inside the lower balance shaft cover are also leaking.
Getting the lower balance shaft cover off with the engine in the car would have been challenging, because the right motor mount bracket is in the way, so I had to remove it. Maybe there's a way to get the housing off without removing this bracket, but I didnt's see a way. At a minimum, I think you'd have to remove the cross-member to get the balance shaft cover off.
Similarly, the oil filter stand seems like it would be a royal pain to remove with the engine in the car, but again, I didn't have to try.
I plan to remove the oil pan tonight, so I may have some insight into your question about the oil pump housing leak soon.
unknown4u - 03-04-2011
[quote name='Cloud9...68' timestamp='1299250682' post='105996']
seems like it would be a royal pain to remove [/quote]
Your diagnose is correct. It was a painfull job but the result was great!.
Glad to hear you were able to get it done. This is a little off topic, but the gasket/o-ring on mine is in much worse shape than the picture Lear35A shows of his in another thread. I'll post pictures of my engine parts soon. So far, the impression of my engine parts is that there seems to be very little wear, but most of my seals and gaskets are leaking. I can't imagine fixing them all with the engine still in the car.
RS Barn - 03-04-2011
Oil pump sealing is tricky when motor is being assembled. There is a surface that needs to be aligned when Crank Cradle is being assembled. I think expanation is only in 944 Service manual. I think Oil Pump housing can be removed and installed with new sealer while Cradle is still fixed. Be carefull of Oil Pump drive gear installation after removal. It needs to fit completely into oil pump drive. You normally need to try several splines to find the spot.
Cloud9...68 - 03-05-2011
I'll take a closer look tomorrow, but I don't think I have any leaks around my oil pump housing, which would be amazing, because pretty much every other seal is leaking. Is the oil pump housing sealed from the block with a gasket or o-ring, or with Loctite 574 (or none of the above)? If mine isn't leaking, should I leave it alone, or should I take it apart while I have the engine out? I'd like to replace any and all gaskets and seals while I have the engine out, but given the cautionary tone in Pete's most recent post, I don't want to create a problem where I don't currently have one, either. Thanks.
Lear35A - 03-05-2011
It's sealed with the Loctite. I can't imagine you wouldn't want to clean & inspect the pump and get fresh Loctite on there.
