New Member - Tucson, AZ -
mocoso973 - 04-04-2023
Hi Everyone,
I'm interested in a 968 but haven't pulled the trigger yet as I'm still learning more about the maintenance of this model. I owned a shark for almost 20 years but I couldn't manage most of the repairs myself. Hopefully a 968 will be friendlier. Cheers!
94SilverCab - 04-06-2023
Welcome,
Enjoy the site!
Regards,
tejon007 - 04-06-2023
Welcome! 968s are awesome.
So, you take a 928 32 valve motor from one of the later 928s. Then you get a big hacksaw and cut it down the middle...you now have a 968 motor pretty much.
Although I'm not saying maintenance on a 968 is half that of a 928. If anything it's worse, especially as more and more parts are no longer available. Not trying to scare you, but realistically a 968 requires special tools (i.e timing belt tensioning tool) and a knowledgeable/skilled mechanic.
paulzebo - 04-07-2023
If you are mechanically inclined, the hardest thing will be getting the car up in the air high enough. I have a lift in my garage so to me it's not a problem. The largest maintenance item will be the cam tensioner pads. Read up on that. It's tedious but not that hard. Plus, you can do the water pump and belts at the same time. The timing belt should be replaced every three years by 1992-1995 standards, but the belt materials have improved over the years with many other manufactures now saying 5-7 years between changes. Read up and make an educated choice. If it's a Tiptronic, be aware the rubber coupler on the flywheel will eventually need to be replaced. I've replaced them in my 2 968's and the cost has skyrocketed to around $2000 per part. If it's a 6 speed, you will eventually need to replace the dual mass flywheel and clutch setup. Both are about the same in parts.
Aside from that, it's a fairly easy car to work on once you get past separating the BS from the facts in your learning curve.
Rap - 04-07-2023
Good luck hunting. Enjoy the ride.
tejon007 - 04-07-2023
"Welcome! 968s are awesome.
Although I'm not saying maintenance on a 968 is half that of a 928. If anything it's worse, especially as more and more parts are no longer available. Not trying to scare you, but realistically a 968 requires special tools (i.e timing belt tensioning tool) and a knowledgeable/skilled mechanic."
Sorry, you only need the tensioning tool for the balance shafts belt, the timing belt on the 968 has an hydraulic tensioner (the 944/951 didn't). Some people don't use the tensioning tool.
IMHO the biggest challenge for maintaining a 968 is that more & more parts are NLA.
"If you are mechanically inclined, the hardest thing will be getting the car up in the air high enough. I have a lift in my garage so to me it's not a problem. The largest maintenance item will be the cam tensioner pads. Read up on that. It's tedious but not that hard. Plus, you can do the water pump and belts at the same time. The timing belt should be replaced every three years by 1992-1995 standards, but the belt materials have improved over the years with many other manufactures now saying 5-7 years between changes. Read up and make an educated choice. If it's a Tiptronic, be aware the rubber coupler on the flywheel will eventually need to be replaced. I've replaced them in my 2 968's and the cost has skyrocketed to around $2000 per part. If it's a 6 speed, you will eventually need to replace the dual mass flywheel and clutch setup. Both are about the same in parts.
Aside from that, it's a fairly easy car to work on once you get past separating the BS from the facts in your learning curve."
It's very difficult to find the correct pressure plate for a 968 when you need to replace it. As for the dual mass flywheel, I think a single mass flywheel is acceptable and, while not "stock", is definitely more affordable.
Again, regular maintenance is doable by us amateurs, but finding parts is what I find to be the challenge.
Waylander - 04-07-2023
Beware of idiot internet 968 mechanics, that replace cam belt tensioner for no reason
they last pretty much forever
parts and finding the correct ones without the massive Porsche tax is the biggest challenge of owning one
welcome
paulzebo - 04-08-2023
100% an the tensioner. No need. Plus, they are no longer in production. Paragon sells the OEM Porsche 968 dual mass flywheel for $2350 and the OEM Porsche clutch setup for $934 should you need it. Beware of aftermarket stiffer pressure plates. The cowl isn't designed for them and may crack. Since you're in Tucson, my favorite parts supplier is
https://www.gaudinporscheparts.com/out of Las Vegas.
Rouhart - 04-20-2023
I once had a light weight fly wheel.
https://www.968forums.com/topic/14877-light-weight-fly-wheel-and-transmission/?p=168848
