Car stops running or won't start. - Printable Version
+---- Thread: Car stops running or won't start. (/car-stops-running-or-won-t-start.html)
Car stops running or won't start. - vineyardcowboy - 08-15-2023
Just started happening. Either takes many tries to start, then when running perfectly it will die and shut off after letting off throttle or coasting. I have a great mechanic and he can't figure it out either. Help!
Car stops running or won't start. - tejon007 - 08-16-2023
Good luck, that's a very difficult problem without much to go on. Have you swapped the DME with a known good one??
Car stops running or won't start. - ds968 - 08-16-2023
Quote: Have you swapped the DME with a known good one??
  + 1
Car stops running or won't start. - Bruckner - 08-16-2023
Quote:Just started happening. Either takes many tries to start, then when running perfectly it will die and shut off after letting off throttle or coasting. I have a great mechanic and he can't figure it out either. Help!
Did you perform a fuel pressure test?
Car stops running or won't start. - vineyardcowboy - 08-16-2023
Okay this is embarrassing. What's a DME?
I'll ask my mechanic if he tested fuel pressure,
Thanks Guys!
Car stops running or won't start. - Waylander - 08-16-2023
The DME relay is a relay that supplies power to the fuel pump when the engine is running
These are a known failure point, I always have a spare in the car
Replacement is a 2 min job
Car stops running or won't start. - dlearl476 - 08-16-2023
This reminds me: I need to stop procrastinating and get a spare.
So the issue is it's receiving fuel fine but no spark. Any ideas on cause? Thanks
Has fuel but no spark is the issue. Any ideas?
It could be so many many things from the ignition switch, wiring harness, coil, distributor, etc.
Wild guess: ignition control module?
Did you get a spare DME relay yet?
Best wishes for a successful fix!
Car stops running or won't start. - unknown4u - 08-18-2023
Check te motronic faultcodes. Perhaps the pickup from the crankcase is worn.
Car stops running or won't start. - tejon007 - 08-18-2023
+1
Ask your mechanic if he/she used a scanner and what codes did she find had been set?
Car stops running or won't start. - Waylander - 08-23-2023
At an educated guess it will be the crankshaft position sensor or its connection.
It could also be the ECU they suffer from dry joints
Car stops running or won't start. - vineyardcowboy - 09-01-2023
It's got a bad coil is the problem. Except we can't find one to purchase. Does anyone know where to get a new or used coil? Thanks
Car stops running or won't start. - Waylander - 09-04-2023
Porsche have them in stock
Car stops running or won't start. - dlearl476 - 09-06-2023
Quote:This reminds me: I need to stop procrastinating and get a spare.
Got my spare from Tech9 yesterday. Great service!
Quote:It's got a bad coil is the problem. Except we can't find one to purchase. Does anyone know where to get a new or used coil? Thanks
Stoddards is the only place I found them available.* (They’re listed on their website, not guarantee they have any in stock) $279.
*That’s just great. After tensioners being NLA for 2-3 years, now nobody has coils. If I can find any specs, I’ll post them. Shouldn’t be too difficult to find a replacement.
Car stops running or won't start. - vineyardcowboy - 09-08-2023
Quote:Well I thought is was the coil. It's not. Problem still exists.
Car stops running or won't start. - tejon007 - 09-09-2023
Not criticizing you here, but can you have another mechanic look at it?
One can easily test a coil with a multimeter. Your problem could be so many things (ICM, crank sensor, wiring, etc.), so you need someone with the skills to troubleshoot it. Just 2 cents worth, & probably worth less than that.
Car stops running or won't start. - Waylander - 09-21-2023
So when you go to start and cranking does the tacho needle bounce?
