Intermittent Radio Problem - Printable Version
+---- Thread: Intermittent Radio Problem (/intermittent-radio-problem.html)
Intermittent Radio Problem - TheJoe - 09-22-2015
My radio sometimes doesnt turn on when the car starts
it still has power, but it seems like it doesnt know the car is started
It used to happen maybe once every couple of months but now its happening everytime i drive it
sometimes after about 30 minutes it will turn on while driving.
Im figuring its the switched power or something related
has anyone else run into this or know where i can start to look
Intermittent Radio Problem - MLB - 09-22-2015
My approach would be to get access to the trigger wire, say at the back of the head unit, check for continuity? Im admittedly weak at electrical troubleshooting, but taking out the center console is pretty straightforward.
As they said on the old I love lucy show, then "just jiggle it a little" :0)
--michael
Intermittent Radio Problem - TheJoe - 09-25-2015
after doing some more research i found out it could be the ignition switch
but in the end it turned out to be a loose fuse in the fuse box
even after pushing it in more, it still comes loose every once and a while
i will have to see if i can secure it better in there
