again radar detector - Printable Version
+--- Forum: NON PORSCHE 968 RELATED DISCUSSIONS (https://968forums.com/forum/non-porsche-968-related-discussions)
+--- Thread: again radar detector (/again-radar-detector.html)
again radar detector - Pitou - 02-10-2005
I'm still in the business for a radar detector.
I have read a comparison about Escort Passport 8500 X50 vs V1
The new Escort came out as winner.
What do you guys think?
Another question:
Can you buy radar detectors in shops in the US (which in case) or only online?
Girlfriend is going to Miami soon....
again radar detector - Larry Currie - 02-10-2005
I like the V1 because it shows the direction of the signal. I don't think you can get it or the Escort in stores.
again radar detector - SANDOVAL - 02-10-2005
Do yourself a favor and invest in a V1. I think the best feature other then letting you know when you have activity. Is the fact hat it gives you the direction of the signal. I remember growing up my dad had one of those gray color thin escorts (80's-90's) traveling back and forth from Santa Fe to ABQ we would play the "where is he game" the sucker would go off a few times during the 50 mile trip. With the V1 you do not have to play that child's game LOL. Check out this new feature. Mike Valentine is a member on another board I frequent he had this to say about the new "Junk" feature. A $55 upgrade if you have the 1.8 version of the unit.
"A New Warning
V1 has a new feature. When the signal identification system determines that a current warning is not, in fact, a radar threat, it notifies you with a "dee-dah-doo" sound and terminates the warning. At the same time, the letter "J" will flash briefly in the Bogey Counter."
"J" stands for "J"unk signal.
OK, why did we add this new feature? Because it was the best way to give beyond-line-of-sight warning capability for POP-radar signals while not burdening the user with an excess of unresolved alerts (false alarms).
POP signals (click me) are short bursts of radar that last only some tens of milliseconds. They are made short in an effort to escape the notice of radar detectors. Simply speeding up the search process of a detector allows high probability-of-intercept for the POP transmissions but introduces another nasty problem -- microwave interference generated by radar detectors in other vehicles causing false alarms.
There are many hundreds of thousands of certain model BEL, Cobra, Radio Shack, and Uniden detectors that manage to transmit radar-like signals that mimic POP bursts to an infuriating degree. They litter the airwaves with interference bursts on the same, exact frequency as, and similar duration to, a real POP-radar signal. Without some way of fending off these "J"unk signals, a detector would constantly nag its user with false alarms from these poorly designed "poluters" in other cars.
The common method of reducing the number of false POP alarms used by our competition is to reduce the sensitivity to POP signals (and their Junk kin) while leaving longer-lasting (over half a second) signals unmolested. This method requires reducing POP-radar range to line-of-sight-only distances in order to give enough relief from detector-generated false alarms to be worthwhile. I wasn't satisfied with only line-of-sight range for POP radar reception, so we pushed for a better solution.
I did nearly 10,000 miles of development driving, dodging speed traps and logging false alarm situations, while our engineers reorganized and optimized the false alarm rejection methods we finally chose. After lengthy deliberations, we realized that it was almost impossible to prevent every POP-like false alarm without taking too large a hit in POP-radar over-the-hill range. I decided that letting in a few POP-junk false alarms initially that were later announced to be "J"unk was less of a problem than not finding out about a POP radar until too late. I hope you'll agree.
My Z8 has LED rear lights and sets off Shank's V1 so incessantly that it needs to be turned off. This is a real problem especially with more and more manufacturers going with LED lights. There is no fix at all in the foreseeable future??
Lou
Lou,
The Z8 actually has neon (not LED) lighting. AFAIK, there have never been any reported problems with LED tail lamp or CHMSL interference with a V1. LED lamp photon output is very slow rise-time (~100 microseconds) compared to a laser-gun pulse (a few nanoseconds) and is easily filtered out in V1's processing circuitry. And, more importantly, the spectral content of visible LED lamps has zero near-infrared spectral content. No near-IR, ... no interference! For these reasons, LED lamps are my favorite new technology for stop, turn and CHMSL lighting.
The neon interference comes from the fact that neon plasma has light emission spectral output in the near-infrared region as well as in visible wavelengths. Red color filters for neon tubes readily pass the near-infrared output as well as the red visible light. Yellow colored neon lamps have a phosphor coating that blocks the near-IR output from them.
And, the typical ignition source for neon is some sort of high-voltage pulsating power supply. The rise-time of the photon output is very fast (~10 nanoseconds), which easily mimics a laser-gun pulse.
Here's a quote from Automotive Industries on the future of neon in automotive lighting (from Jan., 2000 article).
"Neon, featured on the upcoming BMW Z8, competes with LED as another alternative for rear signal lighting, as well as front-of-vehicle applications. Recently, there has been interest among designers in neon CHMSLs, too. Like HID, neon uses gas and does not involve a filament. Lighting makers say it is unaffected by harsh temperatures, shock, or vibration.
Neon comes in tubes that are bendable and allow for design flexibility, and has a faster rise-time than traditional rear lights. It lends itself to applications in which a long, smooth strip is desired.
"Neon lights 200 milliseconds faster than incandescents, giving a following driver 24 feet of extra stopping distance at 65 mph," claims Tom Schottes, global market manager for automotive lighting at Osram Sylvania.
However, today's neon usage is minimal due to extremely high cost. Another downfall of neon is that like HID, it needs an electric ballast.
Federal-Mogul has designed a miniature neon capsule that glows like neon, but uses a different means of energizing gas in the capsule.
"We have been working on neon technology for many years," Jiao says. "There is no committed technology because system cost is not acceptable in a larger scale." He adds that neon is not going to be as widely, or as quickly accepted as LEDs."
So, LED use is growing and that is a good thing. Neon use seems to be waning, but it is already on the road in annoying numbers. We don't have a fix today, but it may be possible in the next few years.
quote:
Originally posted by ebaker
I wonder if a neon light on the front of a car might "confuse" a laser gun?
Probably not.
Laser guns use very narrow bandwidth infrared optical filters to reject "daylight noise" from the sun. They also reject a large portion of potential noise from vehicle headlights.
Unfortunately, neon does not have much spectral energy on exactly the 904 nanometer wavelength used by the laser gun optics. I assume that neon jamming of the laser gun would be largely ineffective because virtually none of its infrared output would travel the past the optical filter.
We can't use that same optical filtering to reject neon CHMSLs(even if we could afford it, which is doubtful) because it only works correctly for an extremely narrow field of view -- less than a few degrees. A laser detector needs a field of view many times greater than the laser gun, so the optically-narrow diffraction grating filters aren't of much use to our side of the war.
Oh well ...
again radar detector - Speedster - 02-11-2005
Tobias,
Have you tried contacting Stu who is behind the porsche 968 uk website http://www.968uk.com His main business is radar detectors, the site to look at is http://www.radar-detector-shop.co.uk/ I'd guess all his are CE approved, if there is such an approval - I know using a detector is illegal in France http://pistonheads.com/gassing/topic.asp?t...france+detector
Tony
Edit - - MODS - I presume it's OK to include links to commercial sites? If not please let me know and I'll delete soonest.
again radar detector - Brian - 01-18-2006
this is the only thread i could find in the archives on radar detectors.
if it's taboo to discuss this topic, just cut this off the board.
if not, what recommendations do you guys have? it would be nice to drive the car w/o worrying. i have very bad luck, even when i'm doing nothing wrong. <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
again radar detector - flash - 01-18-2006
well, first reccommendation is to see if they are legal where you drive - some states have very nasty laws about them tht can end up costing you more than the cost of the speeding ticket
after that, there are a couple of units that have been pretty good, depending on your needs for laser jamming, and your price range
the best unit out there is about 1500 bucks, but there are some decents one for less - here's an article:
http://www.radartest.com/article.asp?articleid=1064
and another site:
http://www.gtimer.com/
again radar detector - ether_joe - 01-18-2006
this is interesting -- I was going to get a V1 but I think I'm going to examine this article more closely. . . V1 seems to be losing its edge?
Thanks for the article link Flash.
again radar detector - Brian - 01-19-2006
thanks for the article. that should be enough info to make a good decision.
it'll give me some reading for my quiet time this afternoon <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />.
one thing - if anyone is looking at that article - make sure you click on the updated article link. the original page is from 2002. the link takes you to 2005.
michigan had a really good state web site with q/a. apparantly detectors are legal, but jammers are not (in any state).
if anyone else is looking up legality - you might also check your state's web site.
again radar detector - flash - 01-19-2006
oops- sorry - grabbed wrong link - thanks for catching that
again radar detector - Harvey - 01-20-2006
V1 will pay for itself.
Harvey
again radar detector - gryphon - 01-27-2006
Looks like Beltronics has a new model, the STi Driver, at $449.95. Has anyone tried it or read a review?
again radar detector - cosimo - 01-27-2006
Virginia is the only state where radar detectors are illegal. Someone in the state legislature tried to repeal this and was defeated. So, if you go through the great Commonwealth of VA make sure your detector is hidden. I have the Valentine V1 and pleased with it's performance. It has saved my a$$ several times. I have it hard wired and mounted above the rear view mirror. VA used to confiscate the detectors but now it's only a fine. Not sure how much as I have not been caught, KNOCK ON WOOD.
