Coffee and the 968 - Printable Version
+--- Thread: Coffee and the 968 (/coffee-and-the-968.html)
Pages: 1 2 3
Coffee and the 968 - Lemming - 03-21-2005
So, what do you coffee drinkers do? I really dislike having to drive around with a hot coffee between my legs, are the any good aftermarket products?
Coffee and the 968 - rustech - 03-21-2005
[quote name='Lemming' date='Mar 20 2005, 08:33 PM']So, what do you coffee drinkers do?  I really dislike having to drive around with a hot coffee between my legs, are the any good aftermarket products?
[right][post="2123"]<{POST_SNAPBACK}>[/post][/right][/quote]
Have you tried wearing a cup? <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
There are a few aftermarket cup holders people have tried including one of the ebay models. None of them in my opinion look like they belong.
[quote name='rustech' date='Mar 21 2005, 12:25 AM']Have you tried wearing a cup?  <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />  <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
[right][post="2125"]<{POST_SNAPBACK}>[/post][/right][/quote]
Good one <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
I've seen the ebay cup holder but I really don't want to put screws into the console.
Coffee and the 968 - pors968 - 03-21-2005
I use the folding cup holder simillar to Griot's garage one. Good german quality and easy to use. Fixed it with 2/4 screws(supplied) between the center mount on rear passanger carpet. (This is just behind the cassete console). No drilling needed. The screws are held in the thick carpet + rubber(under) and you are not making holes in the metal/plastic. Once you remove the screws just rub the carpet, the holes are not visible at all. I'm really a stock person and was really hesitant to fix the cup holder with screws. Looked all options and this was the best for me. Have cup holder in 968 for past 4 years and happy. Can take photos of it if you like to see. I cannot own a car with out cup holder. Spiling the drinks all over and cleaning the mess. not worth. Hope this helps.
http://www.griotsgarage.com/search.jsp?searchtext=cup+holder
Coffee and the 968 - flash - 03-21-2005
go to www.9xauto.com
they have one that requires no drilling or anything like that - it uses the stock mounting screw - i have it and love it
Coffee and the 968 - chazmink - 03-21-2005
I also have the 9xauto cupholder but painted the sheetmetal black prior to installation and mounted two Radio Shack rubber feet behind it to make it more stable. Additionally, I mounted a second cupholder at the rear of the center arm rest by mounting it to a piece of sheetmetal and drilling two holes in it to line up with the two rear armrest/console mounting screws. I bought that one (same as 9xauto and, I believe, Griots) from the Paisley Group at Hershey a couple of years ago for 18 bucks. link to Paisley website http://paisley-group.com/store/flashcart.cfm?section=6
animated link http://paisley-group.com/store/flashcart.cfm?section=6
Charlie
Thanks guys.
Coffee and the 968 - Ave - 03-21-2005
I bought and installed the foldable cupholder from 9xauto.com (same as Griot's I think), but was dissatisfied with the relative flimsiness, and it is difficult to reach while driving. I then bought this item:
eBay cupholders
I know it appears cheap looking, but it works really well. Doesn't really install - it simply wedges down between the passenger seat and the center console. Very stable, holds two drinks safely, and has a center compartment for cell phone or other small items. Doesn't really interfere with passenger seat room, but if it does, it can be pulled out and thrown in the back seat in 2 seconds. I am much happier with it than I thought I would be, since it is so cheap (and no, I have no connection to the seller). Just another option to consider.
Coffee and the 968 - Harvey - 03-21-2005
I put in the folding plastic holder too. Kinda pricey but German made. It's probably the same one that Griot's sells. I parted the carpeting with an icepick (carefully)on the side of the console just forward of the most front most position of the seat and pop-riveted it into place with a small washer on the backside of the carpeting to keep it from pulling out. That way, when I remove it and brush the carpeting back into place no one will notice. To get to it, I reach across the console but, for me, it's more comfortable than any place I've found on the driver's side.
Harvey
No. Idaho
quote=pors968,Mar 21 2005, 08:00 AM]
[right][post="2133"]<{POST_SNAPBACK}>[/post][/right]
Coffee and the 968 - flash - 03-22-2005
but what i want to know is: where the heck do i put my french fries, and what about the ketchup?
Coffee and the 968 - mikeo - 03-22-2005
I must be the cheapskate. The "Wedge" is my choice. It holds 2 cups and has a place for your change, breath mints, or whatever. It fits between the passenger seat and the console. In or out in 2 seconds and very secure. I got mine for less than $5 at Autozone.
Coffee and the 968 - Lemming - 03-22-2005
[quote name='mikeo' date='Mar 21 2005, 11:28 PM']I must be the cheapskate.  The "Wedge" is my choice.  It holds 2 cups and has a place for your change, breath mints, or whatever.  It fits between the passenger seat and the console.  In or out in 2 seconds and very secure.  I got mine for less than $5 at Autozone.
[right][post="2179"]<{POST_SNAPBACK}>[/post][/right][/quote]
I saw one like this at Wally world last night for $3.99, I might have to give it a try.
Coffee and the 968 - trh - 03-22-2005
[quote name='rustech' date='Mar 21 2005, 12:25 AM']None of them in my opinion look like they belong.
Can't you spray paint it white? <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Tristen
Coffee and the 968 - insite94 - 03-22-2005
Chazmink -
Like you and Flash, I also have the 9xauto variety and love it. Do you have a picture of the behind-the-armrest photo you could post? You can never have too many cupholders in your daily driver (unless you are stuck in a minvan) <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
Thanks!
Best driving wishes,
Buzz
Coffee and the 968 - ds968 - 03-22-2005
this is a much easier solution - just fill with Peet's coffee in the morning and you're ready for the commute..
Coffee and the 968 - chazmink - 03-22-2005
Buzz,
I don't have a photo but will try to get one over the next few days. If I cannot figure out how to post it I'll e-mail it to you.
Charlie
Coffee and the 968 - insite94 - 03-23-2005
That's great Charlie. I'd love to see how it gets done. Thanks!
Buzz
Coffee and the 968 - Aus968 - 03-24-2005
I use one i got from a bmw dealer i worked at, it just sits on top of the door pocket, i had to add two little rubber standoffs to make it work, pretty simple but it works great
Coffee and the 968 - josephsc - 03-24-2005
The 9xauto type cupholder can also be mounted in the space between the two rear seats, behind the armrest.
Coffee and the 968 - chazmink - 03-26-2005
Buzz,
Assuming I have inserted the photos correctly here they are. As you can see there is no drilling since the console screws are used. I could have had the cupholder fact the other direction but actually had a remote phone speaker mounted to it with super velcro. I have since replaced that with the cradle for my XM satellite radio. That is also mounted with super velcro. If I screwed up the pictures let me know and I will e-mail them to you.
Charlie         [attachment=232:att
achment]
