Cams, chains and pads...... - Printable Version
+---- Thread: Cams, chains and pads...... (/cams-chains-and-pads.html)
Cams, chains and pads...... - Bart - 03-22-2005
I stopped by Tom Charlesworth's shop today to discuss a chain and pad inspection. He quoted very good rates. Similiar to what I posted at .net last year.
We talked about the job and what was involved if the cams were missing teeth. He has had good luck with repairing the cam sprockets and has them done locally.
If anyone is interested in the service give him a call.
Tom Charlesworth
9802 E. 45th PL.
Tulsa, OK 74146
918-664-8714
Cams, chains and pads...... - insite94 - 03-22-2005
<img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> Whoa!
FWIW, I just got off the phone with Tom - more out of curiosity than necessity. But boy, could I have used that 8 month ago when I bought new cams.
The fact is that there is major concern with warping and gear strength of a repaired/welded cam and gear vs. a new unit. I didn't ask the cost, but Tom reports that he has rebuilt about 20 sets of cams with no failures or issues reported on the rebuilds.
No need to have the car sent to Oklahoma...just send the cams.
Not passing any judgement since I haven't used his services. But it looks like a viable option.
Best driving wishes,
Cams, chains and pads...... - Anchorman - 03-22-2005
GOOD TO KNOW!!! Thanks.
Cams, chains and pads...... - kamran haghbin - 03-23-2005
yea I have been needing to check out my cams and pads, does anyone know the exact process of pulling the valve cover and inspecting?
Cams, chains and pads...... - Greimann - 03-23-2005
[quote name='kamran haghbin' date='Mar 22 2005, 07:12 PM']yea I have been needing to check out my cams and pads, does anyone know the exact process of pulling the valve cover and inspecting?
[right][post="2227"]<{POST_SNAPBACK}>[/post][/right][/quote]
Exact, like bolt for bolt? I think you are a good enough wrench to pull the valve cover.
Once off, the thing you are looking for are missing teeth on the cams. Bump the motor over on the starter, or turn the crank and and look at all the teeth.
Also look at the tops of the teeth and look for knife edging. A normal cam gear will have a land at the OD of the tooth. One that is wearing thin will come to a sharp point at the tip.
Also, look at the tensioner pad between the links of the chain. If there are deep grooves, say more than .020" (the thickness of a credit card), then it might be a good idea to start planning a tensioner and chain job. Small grooves or scuffs are OK.
Cams, chains and pads...... - Etnier - 03-23-2005
[quote name='kamran haghbin' date='Mar 22 2005, 10:12 PM']does anyone know the exact process of pulling the valve cover and inspecting?[/quote]
The DIY is here.
Cams, chains and pads...... - Vedder - 04-05-2005
Its possible to take the valve cover off, and just replace the pads without taking the chain off??
this in case of the chain and cams look fine?!
Money is a bit short lately...?!!
Cams, chains and pads...... - Anchorman - 04-05-2005
Changing the two pads requires removing the cams. Once you've done that, I'll bet the chain looks simple.
Cams, chains and pads...... - NeedPorscheSpeed - 04-05-2005
Vedder, I am in the process of doing this very job. Are you planning to do this job yourself? If so, I would be glad to share the pictures I have taken as the job has unfolded with you. Just let me know. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
I think many of us would welcome the opportunity to share from your experience - and your photos.
[quote name='Anchorman' date='Apr 5 2005, 03:32 PM']I think many of us would welcome the opportunity to share from your experience - and your photos.
[right][post="2867"]<{POST_SNAPBACK}>[/post][/right][/quote]
Excellent! I have been waiting for an opportunity to contribute to the DIY section. From this point on, I will proceed with the job with the idea of creating a comprehensive write-up of this job. I am still unsure as to just how deeply into the engine I must go. So far, I have removed the valve cover, performed both cylinder compression and leak down tests. At a bare minimum, I will be replacing both camshafts, the upper and lower tensioner pads, and the camshaft timing chain. There is also a possibility that I will pull the head and have it freshened. I am weighing my options right now. I could go ahead and post pictures of the work I have done so far, if anyone is interested. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Cams, chains and pads...... - Vedder - 04-06-2005
Yes ,im very interressed in the whloe process, the more detailed the better, I wanna tackle this job by myself, i just need more information.
I dont wanna anything to go wrong.
Cams, chains and pads...... - NeedPorscheSpeed - 04-07-2005
[quote name='Vedder' date='Apr 6 2005, 02:17 AM']I dont wanna anything to go wrong.
[right][post="2902"]<{POST_SNAPBACK}>[/post][/right][/quote]
I know the feeling! <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Cams, chains and pads...... - Vedder - 04-07-2005
Does anyone know the part number for the pads? what that about a beefed up timing chain??, and /or have a explode diagram of the timing chain area?
[quote name='Vedder' date='Apr 7 2005, 12:11 PM']Does anyone know the part number for the pads? what that about a beefed up timing chain??, and /or have a explode diagram of the timing chain area?
[right][post="2957"]<{POST_SNAPBACK}>[/post][/right][/quote]
Here you go:
Upper Tensioner Pad--944.105.509.00
Lower Tensioner Pad--928.105.509.01
Camshaft Timing Chain--944.105.501.05
Here is the exploded diagram, Vedder.
(Moderators: I hope it is okay to post this diagram. If not, feel free to delete.)
Cams, chains and pads...... - apex - 04-07-2005
NPS thanks for chasing down those elusive numbers.
I ordered two chain pads from Sunset a while ago - now I wonder if I got two of the same. <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" /> What exactly is the difference between the upper and lower?
Cams, chains and pads...... - Greimann - 04-07-2005
[quote name='NeedPorscheSpeed' date='Apr 7 2005, 01:33 PM'](Moderators:  I hope it is okay to post this diagram.  If not, feel free to delete.)
[right][post="2974"]<{POST_SNAPBACK}>[/post][/right][/quote]
Post away. I do it all the time. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Cams, chains and pads...... - SANDOVAL - 04-07-2005
I agree the more visual info the better!
Cams, chains and pads...... - NeedPorscheSpeed - 04-15-2005
[quote name='apex' date='Apr 7 2005, 04:58 PM']NPS thanks for chasing down those elusive numbers.
[right][post="2987"]<{POST_SNAPBACK}>[/post][/right][/quote]
Apex, if you installed two upper pads, that should be just fine. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> Actually, I am back to a state of confusion concerning the pad issue. See post #7 in this thread:
http://www.968forums.com/index.php?showtopic=399
