Tire pressure - Printable Version
+---- Forum: Tires (https://968forums.com/forum/tires)
+---- Thread: Tire pressure (/tire-pressure--16224.html)
Tire pressure - 944_968CS - 04-26-2005
Hello,
I have ordered Ecsta MX 235/40 x 18 and 265/35 x 18 for my 968 CS. The rims are 8,5 and 10 inch wide.
What should the pressure be for cold tires?
The car has Bilstein Club Sport Coilover set up and M030 Sway Bars
I apricate Your help.
Kind Regards
/Bosse P
Tire pressure - Jason Judd - 04-26-2005
I don't know this Kumho model at all...
But, when I ran the Ecsta V-700's they reccommended HOT pressures of about 40 psi...of course you will have to adjust accordingly.
If I remember correctly, my COLD pressures were about 30 psi.
The best way for me was to get to the correct HOT pressure and let the car sit after the track session and then take the cold temp's. That would be my new COLD temp baseline.
Jason
