Cross Sports Suspension Coil-overs - Printable Version
+---- Thread: Cross Sports Suspension Coil-overs (/cross-sports-suspension-coil-overs.html)
Cross Sports Suspension Coil-overs - mech - 05-02-2005
They are expensive, but they are new to me.
http://www.eightyonemotorsports.com/produc...2hcrossless.htm
Cross Sports Suspension Coil-overs - bluett - 06-01-2005
If you want more pictures of them they are in my 968 folder. I had them for a while on my 968 street car and they will go in my 968 race car. They perform very well once installed and configured correctly.
cross photos...look under 968 folder
Cross Sports Suspension Coil-overs - SANDOVAL - 06-01-2005
it's been a long time! How is your car coming along? Every once in a while I think about your project and wonder what has come of it. BTW The TT looks gorgeous. Glad you found us.
Eric
yup I just found this place....I'm soooo slow at these things!!! Good to see some familiar faces.
The 968RS project has slowed, but that's only because I've been working on my 964 project. I should be done with my 964 within a couple of weeks. Then I'm going to concentrate on the 968RS. I've been accumulating some parts for the 968 but still need some bodywork parts.
Btw anyone know what the 968TurboRS's used as fuel cells?
Winston
Cross Sports Suspension Coil-overs - us944 - 06-02-2005
[quote name='mech' date='May 2 2005, 06:25 PM']They are expensive, but they are new to me.
[right][post="4089"]<{POST_SNAPBACK}>[/post][/right][/quote]
I am considering the Cross coilovers. What did you do in the rear, did you remove or reindex the torsion bar?
Cross Sports Suspension Coil-overs - bluett - 06-03-2005
I removed the torsion bars. I believe the springs rates were designed to be used without the torsion bars, but I think you can order special spring rates if you really have to have them. I would call JIC/CROSS to see what meets your needs.
