When starting cold... - Printable Version
+---- Thread: When starting cold... (/when-starting-cold.html)
When starting cold... - sasilverbullet - 06-07-2005
Does your car run kinda rough for about 3-5 seconds? (sounds like it's missing)
Chime in folks, let me know...
When starting cold... - Greimann - 06-07-2005
Nope. Sounds like a contented kitty.
When starting cold... - bob blackwell - 06-07-2005
No, it runs very smooth at idle speed after start up. Good luck, Bob Blackwell.
I've ordered a new cap and rotor. Let's see if that clears it up...
Thanks for the feedback!
If anyone else wants to chime in, go ahead...
When starting cold... - dlearl476 - 06-16-2005
[quote name='sasilverbullet' date='Jun 7 2005, 10:42 AM']I've ordered a new cap and rotor.  Let's see if that clears it up...
[right][post="5528"]<{POST_SNAPBACK}>[/post][/right][/quote]
While on the subject of start-up issues, let me run this one by y'all:
Belts/pulleys have less than 2500 miles on them. When I start up cold, (well, as cold as it gets here in Las Vegas) I have a bit of "whine" for maybe 1-2 minutes. And yes, the re-tensioning/check was done on time.
Should I be concerned? Doesn't sound "bad", just a cold pulley.
When starting cold... - rustech - 06-16-2005
Sounds perfectly normal. That is how some of us tension our belts along with the twist method.
