TOP NOISES ET ALL - Printable Version
+---- Forum: Cab Top & Boot Cover (https://968forums.com/forum/cab-top-boot-cover)
+---- Thread: TOP NOISES ET ALL (/top-noises-et-all.html)
TOP NOISES ET ALL - flash - 11-25-2005
ok, so we've all heard about:
weird drive noises
moaning and groaning
rattles in the top frame, usually at the header rail
here's the question though:
after setting the top in manual mode, has anybody noticed any new rattles in the fram itself, at the side of the car? i had ayn drive it (that was an adventure all by itself) while i listened - sure enough, the frame is rattling - if i grab it, it goes quiet - my theory is that the washer and bolt that are loosened to make it in manual mode are loose and rattling, or allowing free play in the mechanism
i am almost done with the in and out of stuff in the car, so i will go back to power mode soon, but i was just wondering if anybody else has noticed this particular phenomenon
it may just be my car, because everything is now so stiff, and i've gotten rid of most of the rubber suspension bushings, and this kind of thing is likely to happen
it's the only rattle i have though, and i am determined to get rid of it
TOP NOISES ET ALL - SILVY968 - 11-26-2005
I also have the same rattle on the passenger side where the top pivots. It is hard to pinpoint while driving and I have not asked someone to drive me around while I listen, GULP!
If I am going to stay manual, what can I do to tighten things up and still allow manual movement? What if I just remove the "manual" bolt to stop it from rattling? If I am going to stay manual I guess that I could also remove weight by pulling the motors and trans. cable assemblys, That stuff must weight 15#.
How can I eliminate looseness in the frame?
I will try and work on it this weekend and post what I find.
TOP NOISES ET ALL - flash - 11-26-2005
i am planning on taking a better look in there tomorrow, but since the manual says to loosen in up 3 turns, there isn't likely much that can be done - anything that would reduce the rattle will likely also add friction, and then BOINK
best of luck removing all the stuff - that is a very aggressive project - it's no fun getting to that stuff underneath the shelf
Boy, you are right!
You could take the top off of the car and try to get under the shelf to get out the motors, but it is a very big undertaking.
I am going to leave the motors etc. in the car.
When I go back to electric mode the rattles should go away.
pretty much my thought too
i found out how much fun it was to get to the motors when i had the cr shot - i had to nearly remove the top to avoid a masking line, and it revealed the top works
not planning on getting back in there any time soon if i can help it
968 montra:
"I can see it, but I can't get to it."
These cars must have been assembled with the aid of very small German monkeys.
TOP NOISES ET ALL - rustech - 11-27-2005
[quote name='flash' date='Nov 26 2005, 11:10 AM']i am planning on taking a better look in there tomorrow, but since the manual says to loosen in up 3 turns, there isn't likely much that can be done - anything that would reduce the rattle will likely also add friction, and then BOINK
[right][post="12822"]<{POST_SNAPBACK}>[/post][/right][/quote]
I wonder if adding a couple nylon washers (double stacked on each side) in the mix would help reduce friction and allow them to be tightened down more but yet maintain manual mode.
TOP NOISES ET ALL - flash - 11-27-2005
sure worth looking at - i'll be in there today, now that mark has come and gotten his car and is on his way - i'll let ya know what i found
