1993 968 Tiptronic torque tube replacement -
edm - 01-25-2017
Need help, My mechanic has informed me that my issue with my 1993 968 Tiptronic Cab is the torque tube, and we are having a very difficult time in trying to track one down. can anybody point us to someone or a vendor that I can get this part?. Any help is appreciated.
flash - 01-25-2017
why would you replace the entire tube? normally you just replace the bearings
968Syncro - 01-25-2017
There is one on ebay, in the UK, a little over $200. Item number: 282234708712
Also do a search on "Porsche 968 torque tube" and some rebuild places surfaced.
flash - 01-25-2017
there is one on each coast that i know of, and have done work for me, with which i was satisfied. the best one is black sea.
edm - 01-25-2017
Called Black Sea and they were very helpfull and informed me that I would need a SPLIT torque tube and they don't service this part.
flash - 01-25-2017
weird. the last time i talked to them, the one that they would not service was the split tube. maybe they meant that you had a split one, and they won't do those, because typically they do a core/exchange deal. check and see if yours has a split in it. basically it would look like a 1/8 "-1/4" wide slot at one end.
edm - 01-25-2017
You are correct, I have the split one and they don't service those. Any advise????
banditsc - 01-25-2017
They sell the bearings that your mechanic could install in your tube, they just don't service the split ones.
Guess this answers it.
http://www.blackseard.com/site/index.php?option=com_content&view=article&id=9&Itemid=11&limitstart=2
Grandpa#3 - 01-29-2017
EDM, you might get some help on a post over on R.L..
Well I can not delete the below link for some reason. Go over to Rennlist.com and on the Water Cooled 944 / 968 postings look for the post of Der Treiber , TT Bearing question , 1-19-17. This is a good post and even shows the pictures they are talking about how to affix the bearings with steel pop rivets.
http://rennlist.com/forums/924-931-944-951-968-forum/971602-tt-bearing-question.html
Cheers,
Larry
94SilverCab - 01-30-2017
Quote:EDM, you might get some help on a post over on R.L..
Well I can not delete the below link for some reason. Go over to R.L..com and on the Water Cooled 944 / 968 postings look for the post of Der Treiber , TT Bearing question , 1-19-17. This is a good post and even shows the pictures they are talking about how to affix the bearings with steel pop rivets.
Cheers,
Larry
We do not allow cross posting from other 968 sites.
edm - 02-20-2017
My mechanic tracked one down at DC auto and it worked out, all is good, hopefully nothing else goes wrong. Thanks to everyone who replied .
