Low cost Flywheel? - Printable Version
+---- Forum: Clutch & Flywheel (
https://968forums.com/forum/clutch-flywheel)
+---- Thread: Low cost Flywheel? (
/low-cost-flywheel.html)
Greimann - 02-21-2006
In browsing one of these OEM parts fulfillment web sites, I ran across a Sachs flywheel for the 968 for $261!
Link here: Sachs flywheel
Has anyone looked into this? The description does not mention dual mass, but it says OEM spec. Kinda confusing.
flash - 02-21-2006
10 mounting holes? how dey doo dat?
The caption of the picture says it may not be representative, so it must be a file photo.
flash - 02-21-2006
the price is right, based on comparison to paragon, for a 924S, 83-89 944, and a 944 turbo - sounds confusing for sure
worth looking into for sure
Lemming - 02-21-2006
It may be the same flywheel that is used in the 944S2, which is not dual mass. That's what I run in my trackcar and it bolts directly to the 968 engine no problem.
flash - 02-21-2006
what's the weight?
do you get the same resultant rattle in the transaxle the light flywheels do?
can you use a spring center disk?
Eric_K - 02-21-2006
It's probably a mistake. Sachs pressure plate maybe.
BTW, a S2 flywheel will not work in a 968 bellhousing.
Eric
[quote name='Eric_K' date='Feb 21 2006, 01:30 PM']BTW, a S2 flywheel will not work in a 968 bellhousing.
Eric
[right][post="16322"]<{POST_SNAPBACK}>[/post][/right][/quote]
Didn't know that, my track car actually runs the 924S bellhousing which is a direct bolt on to the 968 engine.
Eric_K - 02-22-2006
The end of the crank and the engine to bellhousing mounting points are the same among 944, 951, 968 - which explains why your setup works. The 968 has a longer bellhousing to accomodate the thick dual mass fw and has a shorter torque tube.
Eric
