Cabrio 3rd brake light bulbs and LED's - Printable Version
+---- Thread: Cabrio 3rd brake light bulbs and LED's (
/cabrio-3rd-brake-light-bulbs-and-led-s.html)
TonyBray - 02-23-2006
Ok, so the first thing I do when I buy a car and check all the light bulbs around the car. None of my 3rd brake light bulbs worked. I pulled the light fixture and checked each bulb with an ohmmeter to make sure the bulbs were bad and it wasn't a wiring problem since the wire leading to them looks like it could kink and break where it enters the trunk lid. The bulbs are "capsule" type. Porsche wants $13.70 each for them little suckers! I searched the internet and found this:
Capsule Bulbs
It should be easy to match our bulbs up to these if someone knows the wattage of the stock units.
But I didn't go this route! I found the article at 968Engineering.com. I have a bunch of LED's at home but only had 1/4 watt resistors. So I headed to the local RadioShack in search of the correct resistor. While there, I checked through their selection of LED's and found these:
Jumbo Red LED The larger size is perfect for the tail light. On the cabbie at least, the bulbs are held in by the wires. I trimmed the wire leads down on the LED's and pushed them into the holder that held the original bulb. Then I cut the positive wire inside the light fixture and soldered in my new resistor. These large LED's are really bright. Back on the car, you cannot tell they are LED's from the outside. I didn't have to take the bulb holders off the board. I didn't have to remove the original reflectors. I didn't have to drill the board to add 3 more LED's. Total cost was around $10 and took less than 5 minutes to assemble once the fixture was off the car and the soldering iron was hot.
I'm not trying to take anything away from the 968Engineer, it's a brilliant idea. Maybe he hasn't seen the larger, brighter LED's yet? Either way, it's an alternative. Or, someone could match up the stock bulb on the bulbs.com site and then you can get them really cheap (about what I paid for each LED at the Shack).
--Tony
Anchorman - 02-23-2006
Interesting - thanks for the info. My longer term, and more ambitious, plan is to remove the third brake light from the deck lid and install a (different) light in the rear panel where the 968 numerals are. This would result in a look akin to the BMW 3-series convertibles. I have all of the necessary "stuff" to do this - a spare panel section and a light from a 993 that looks like it would be perfect fit. The mounting of the modified panel is the part I haven't worked out yet, as cutting the opening for the light will interfere with two of the four stock mounting points. It would be much easier to do this if the car wasn't a daily driver.
Greimann - 02-23-2006
Hey, good deal. Always room for better mouse traps. Snap some pictures put a DIY in the DIY section.
Don't worry about taking food out of my doggies mouth, I just do this stuff as a favor for those who are not so hands on.
We need more innovation from capable people and suppliers.
Greimann,
I will be hitting you up on the alarm piece for opening the hatch anyway..
I will put the article together when I can. I have been writing articles for the 912Registry Magazine for a while so I appear to be getting good at it <img src="/forum/images/smilies/968/wink.gif" class="smilie" alt="" />
BTW, I didn't make the connection that you were the 968 Engineer. Huntington Beach too. You going to the LA All Euro event Sunday? If so, look forward to meeting you.
--Tony
rxter - 12-31-2009
What is the "right" resistance? The link is to a red light. If I stay with teh red lens I'll want a white light. Would this one work?
http://www.radioshack.com/product/index.js...oductId=3125355
And what did you all do about the gasket? not surprisingly it has pretty much disintigrated over time.
