968 Chip.......What is the story - Printable Version
+---- Forum: Chips and Salsa (ok - no salsa) (https://968forums.com/forum/chips-and-salsa-ok-no-salsa)
+---- Thread: 968 Chip.......What is the story (/968-chip-what-is-the-story.html)
968 Chip.......What is the story - Kaj Hallstrom - 07-14-2017
I have no experience with (nor knowledge off) installing a chip into my car. So, what do I need?. Does it affect my smog check in CA?
Fill me in Gentlemen.
968 Chip.......What is the story - az968 - 07-14-2017
I have the RSBARN Stage 1. I had a Weltmeister chip in the car when I bought it and didn't know until swapping chips. I like the RSBARN one better.
Replacing the chip,is pretty straightforward, but different ECUS need different versions of the chip. I would give Pete a call and discuss your specific car. You may need to pull the old chip or not first to get there version number. i did not have to for my 93.
968 Chip.......What is the story - Rap - 07-14-2017
Ditto. I have had the RS Barn chip in all my cars and have been pleased with the results.
968 Chip.......What is the story - 94SilverCab - 07-14-2017
Kaj,
Seriously...there are about 400 threads on this topic. Please do a search, read everything you can, and then, if it is even remotely possible that you have a question, go ahead and ask.
Refer to the ENTIRE SECTION called "Chips and Salsa"
968 Chip.......What is the story - flash - 07-14-2017
since it didn't click the first time, i have moved this thread to the appropriate, and aforementioned area
968 Chip.......What is the story - lbpesq - 07-14-2017
I replaced the chip in my cab when I first got it. I've passed California smog several times since. Go for it.
Bill
