power steering pulley on crank - Printable Version
+---- Forum: Engine (
+---- Thread: power steering pulley on crank (
/power-steering-pulley-on-crank.html)
mefforddk - 11-24-2006
I was re-installing the power steering pulley onto the crank yesterday, when I noticed a small counter-weight. Since I didn't mark the orientation when I removed the pulley <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> , I've probably lost the balance. I did notice a small dab of paint on the AC pulley that might have been left over from the previous timing belt change. I may try that for my intial alignment.
Any ideas on getting that pulley lined back up?
Mefforddk
flash - 11-24-2006
you could try and disconnect the belt, and then spin the pulley in each position and leave it where it spins the most turns
968rz - 11-24-2006
I'm just pulling this one out of my butt but, I would think that is to balance the pulley itself and the position wouldn't matter as long as the weight is still there.
mefforddk - 11-25-2006
[quote name='flash' post='28259' date='Nov 24 2006, 08:57 AM']you could try and disconnect the belt, and then spin the pulley in each position and leave it where it spins the most turns[/quote]
Good point. Flash I can't spin it freely as it is attached to the crank. If I can I got bigger problems. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Anyway, I just got the car running after re-building the head and replacing a few parts in the the timing belt area, water pump, balance shaft seals. etc.
Car runs great. Now to wrap up a few loss ends and she's road worthy again.
