My Alarm needs an Exorcist!! - Printable Version
+---- Thread: My Alarm needs an Exorcist!! (/my-alarm-needs-an-exorcist.html)
My Alarm needs an Exorcist!! - sker66 - 02-02-2007
..........My alarm is possessed!!
I am having an issue with my alarm going off intermittintly without reason! No noise,trucks,harley's etc.
I found a replacement alarm module and at first i did some tests during the day and it seemed OK. That night i left it on and no issues. Last night while i was in a dead sleep it went off for no reason at 12 midnight. Thats two different modules . I kept it on all day at work todayand all was fine again.
Has anyone that has had this issue or is very knowledgeable in this area. I really need it as i park the car outside overnight and i really don't want to bypass it and install an aftermarket one if i don't have to.
Thanks..............G <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
My Alarm needs an Exorcist!! - flash - 02-02-2007
very likely a pin switch is knackered - check the ones at the doors, hood, trunk (or hatch) and definitely the one in the glove box
My Alarm needs an Exorcist!! - Allen1322 - 02-05-2007
I had the same issue. I had a few things to fix, and finally found the culpret.
My rear hatch wire frayed and was disconnected, but that just made the module think the hatch was closed all the time.
My hood switch wires had been knawed through by a rodent and were exposed. If they somehow touched, this would have caused the alarm to go off.
But what was the real culpret (and probably yours too) was the glovebox. The glovebox switch doesn't get pushed in very far when the door is closed. Mine was only getting pushed in JUST enough to turn the light off. To check out if this is your problem, push down on the door while it is closed and latched.(do this at night or someplace dark. If you see the light come on inside, this is triggering the alarm. There is a screw that adjusts the depth of the door latch. Tighten this so that you can't trigger the light when the door is latched.
If this is not your problem and you still want to lock your doors without arming the alarm, there is a precedure.
Get out of car, open passenger door, use central lock button inside car, close passenger door. This will lock the doors w/out arming the alarm like locking the doors w/ the key does.
Good luck.
My Alarm needs an Exorcist!! - sker66 - 02-05-2007
Thanks guys..........I'll try those things and let you know if it helped................cheers
