What's part# for the low temp thermostat & fan switcth? -
sasilverbullet - 03-14-2007
What is the part #'s for the low temp fan switch and the low temp thermostat?
Here's what I found for a low temp switch:
pelican parts fan switches
I can get a 75, 85 or 92 - which one should I get? <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" />
I saw another post saying get the one for a 90 VW vanagon <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Low temp thermostat? Where, what part #?
Stephenwz968 - 03-14-2007
Scott Collins just did his fan switch, he'd know the part number-
Steve
rustech - 03-14-2007
The low temp fan switch was originally designed for the 90 VW vanagon, that is why it is often referenced as such.
IIRC, I'm running the 85c Thermostat while 92c is stock.
I'm going with the 72c, which is about 161 fahrenheit on the switch.
Now anyone know where i can get a 160 degree thermostat?
I just called Jones Autowerks - Kathy's getting the part numbers and i'll post them when I get them...
gryphon - 03-14-2007
What are the advantages and disadvantages of a colder thermostat? Wouldn't running at a lower temp reduce efficiency slightly?
Tom
Before flash chimes in with the phd detail <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> From my layman's level - It's HOT and muggy down here 10 months of the year and I drive my car all day long, every day in stop and go traffic. So, I'd rather have the guage at the bottom white line than right near the top one cuz it's so damn hot down here!
251-959-481-75 fan switch 75 degrees
056-121-113-71 thermostat 71 degrees
