Oil drain plug - Printable Version
+---- Forum: Parts is Parts (https://968forums.com/forum/parts-is-parts)
+---- Thread: Oil drain plug (/oil-drain-plug.html)
Oil drain plug - SILVY968 - 01-21-2008
I just saw a magnetic drain plug for the oil pan on eBay.
Sounds like a good idea.
Is the OEM oil drain plug magnetized?
Oil drain plug - PorscheDude - 01-22-2008
I don not think it is. This is a great thing to monitor and prevent engine wear. Pick up new crush washers to go with your new plug.
Oil drain plug - 94SilverCab - 01-22-2008
OEM Oil Drain Plug is NOT magnetized.
Oil drain plug - Cloud9...68 - 01-22-2008
I actually ordered a magnetic drain plug for the 968 from a company called SuperPlug, from whom I had ordered for other cars I have owned. Unfortunately, the one they sent me for the 968 was too long - the shaft which contained the magnet bumped into something inside the pan, which prevented me from threading it. So you might want them to measure it when ordering it; if it's more than about 1/2" long, it's probably too long. Good luck.
Oil drain plug - flash - 01-22-2008
while this all seems to make sense, and i know that plenty of people swear by these things, i am not a fan of magnetic plugs, and have a slightly different view of them
i tried them a long time ago, and some of the particles that WERE stuck to the plug got dislodged on the track, and found their way to places in the engine i did not want them
as a result of spending time stuck to the plug, they inherited some of the magnetism - consequently they stuck themselves to other iron parts when they got dislodged, and finally got into a bearing journal - when we took it apart, there were tiny little fragments stuck to the bearings
i prefer to merely change my oil more frequently than i do to change my bearings
Oil drain plug - SILVY968 - 01-23-2008
[quote name='flash' post='46164' date='Jan 22 2008, 04:52 PM']while this all seems to make sense, and i know that plenty of people swear by these things, i am not a fan of magnetic plugs, and have a slightly different view of them
i prefer to merely change my oil more frequently than i do to change my bearings[/quote]
Flash,
Is the transaxle plug magnetized? If so, how does the above logic hold up?
[quote name='Cloud9...68' post='46162' date='Jan 22 2008, 04:46 PM']I actually ordered a magnetic drain plug for the 968 from a company called SuperPlug, from whom I had ordered for other cars I have owned. Unfortunately, the one they sent me for the 968 was too long - the shaft which contained the magnet bumped into something inside the pan, which prevented me from threading it. So you might want them to measure it when ordering it; if it's more than about 1/2" long, it's probably too long. Good luck.[/quote]
here is the link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...275477&rd=1
I asked about the length. I'll post the reply.
answer back:
"this one is exactly a 1/2 inch from the beginning to the end of the thread."
brian
Oil drain plug - flash - 01-23-2008
i don't know if it is or not - i'm not inclined to add one though if it isn't, and plan to change the fluid every 5000 miles on that as well, as i am pretty hard on trannies
Oil drain plug - biotechee - 01-23-2008
Am I the only one who is going to razz you about your treatment of a certain group of individuals? Please don't provide details, my virgin ears couldn't bear it....
And if your treatment of cars is any indication of your treatment of trannies, then I would suppose they are some clean sumsabiatches!
roflmao - funny stuff - just saw that - not going to further get into changing of fluids on trannies
Oil drain plug - Georges - 01-23-2008
Flash -- how often do you recommend changing the air in the tires?
Oil drain plug - 94SilverCab - 01-23-2008
Not Air...Nitrogen...LOL
Oil drain plug - Cloud9...68 - 01-24-2008
[quote name='SILVY968' post='46180' date='Jan 22 2008, 09:35 PM']answer back:
brian[/quote]
Brian,
If you decide to go with a magnetic drain plug, the one you describe should fit. The one I had must have stuck out a good inch beyond the last thread. Flash makes an interesting point, though. Not sure which way to lean on this one...
Oil drain plug - SILVY968 - 01-24-2008
[quote name='Cloud9...68' post='46266' date='Jan 23 2008, 08:14 PM']Brian,
If you decide to go with a magnetic drain plug, the one you describe should fit. The one I had must have stuck out a good inch beyond the last thread. Flash makes an interesting point, though. Not sure which way to lean on this one...[/quote]
Logic tells me that it should be a good thing, but if flash does not bless it, I will pass. I have spent many hours talking with him and reading his post on this forum and others, and he simply has a great wealth of knowledge. Many of his opinions are directed to a 968 that is modified for handling, weight balance etc; and as I have a DD, many of his mods do not apply for me, but if Porsche did not see fit and flash has reservation, I'll pass.
Oil drain plug - FRporscheman - 01-26-2008
All 944s and 951s came with a magnet in the oil drain plug. I don't know why they took it off for the 968, but I have 944 drain plugs on both my 968s now. To each their own.
I have never seen a tranny drain plug with a magnet.
Oil drain plug - flash - 01-27-2008
possibly because of the aforementioned issues
Oil drain plug - FRporscheman - 01-31-2008
Bob, I just reread that story about the metal bits in the bearings... yikes.
Oil drain plug - flash - 01-31-2008
yeah - pretty much sucked - the part i didn't mention is that the reason we had to tear it down was a failure in a race we were winning - the engine would easily rev 8800 - right up until a bit of metal got in there - NASTY noise at 8800
Oil drain plug - SpeedRacer64 - 01-31-2008
[quote name='flash' post='46647' date='Jan 31 2008, 08:01 AM']yeah - pretty much sucked - the part i didn't mention is that the reason we had to tear it down was a failure in a race we were winning - the engine would easily rev 8800 - right up until a bit of metal got in there - NASTY noise at 8800[/quote]
I wasn’t aware there was a crush ring on the drain plug...probably why it’s leaking...I thought it didn’t require one...and surmised the leak was from the shop installing a nylon one not reaching proper torque...does anyone have the part number on hand for 944/951 magnetic drain plug?
Tks
Oil drain plug - gryphon - 01-31-2008
[quote name='SpeedRacer64' post='46661' date='Jan 31 2008, 11:06 AM']I wasn’t aware there was a crush ring on the drain plug...probably why it’s leaking...I thought it didn’t require one...[/quote]
Walmart's automotive service centers are also not aware of this. Don't ask me how I know.
Tom
