Brake pedal adjustable? - Printable Version
+--- Thread: Brake pedal adjustable? (/brake-pedal-adjustable.html)
Brake pedal adjustable? - m-wilhelm - 02-21-2008
My brake pedal is quite a bit higher than the gas pedal. I was looking behind the brake pedal and it seems like the height might be adjustable. Has anyone tried this?
I rarely ever post and I'm confused with all the new categories so I'm not sure where this post should live.
Brake pedal adjustable? - m-wilhelm - 02-29-2008
Anyone?
Brake pedal adjustable? - bob blackwell - 02-29-2008
Sorry for the lack of response. I have only adjusted the spring pressure for the clutch but not the brake pedal. There is an adjustment for "toe clearance" of the brake pedal which should change the pedal height a bit. You will find this adjustment on the rod that goes from the brake pedal to the master cylinder. Good luck, Bob Blackwell.
Brake pedal adjustable? - 968rz - 02-29-2008
I've never adjusted the pedal on the 968 but did try it on my 924 (once) as the pedal seems low. All that did was to put pressure on the pads non-stop and cause red rotors and smoke at stop signs. I put it back as it was ASAP and never looked back.
