Water pump installation -
Cloud9...68 - 03-25-2008
I've removed my old water pump, and it doesn't look like there was any sealant against the gasket. Is it recommended to used sealant with these pumps, or just go with the gasket alone? Every other water pump I've ever replaced or other cars, I've always used sealant, so I'd like to hear the consensus on the 968. Thanks.
josephsc - 03-25-2008
I've never used sealants on 944/968 water pumps -- just gaskets. And I've only overheated one engine (and I didn't do that water pump job...)
unknown4u - 03-25-2008
if the surface is flat, from pump and engine, there is no need to use an extra sealant. The gasket wil do the job properly.
968rz - 03-25-2008
I agree with everyone else (no sealer); if needed you could use a little weather strip adhesive to hold the gasket while installing but that's it
xrad - 03-25-2008
I always use a touch( a very light nearly 'see through' smear on both cleaned surfaces..not allowing excess into engine) of permatex orange silicone sealant in conjunction with the gasket to fill in little nooks and crannies in aluminum...never had a leak in numerous rebuilds of various engines..
BUT: some sealants and sealant additives are corrosive to aluminum.......
Also: any time I re-insert a bolt into aluminum, the holes and threads are cleaned and blown dry and I use a small dab of aluminum neversieze in the hole....
968rz - 03-25-2008
Using silicone on gaskets is bad, silicone cures with a chemical process that can weaken the gasket and cause early failure.
xrad - 03-25-2008
Have not performed a blind study, but the room temp vulcanization (RTV) process silicone of the 'claimed' non-corrosive Permatex brand has worked well for me...(Probably on ~200 engine gaskets-excluding head)
Pressed paper and synthetic gaskets generally seem to remain flexible and come off more easily
additionally, RTV silicone has a hydrophobic as well as glycol resistant bond which can aid in H20 pump leak suppression.
Thanks for the responses. It sounds like the consensus is to forego the sealant.
And thanks, xrad, about the tip for the aluminum never-seize. Is this a commercially available product? Where do you buy it?
xrad - 03-25-2008
little jug with brush...
find aluminum never-seize at NAPA or similar.
http://www.acehardwareoutlet.com/(oezwd1aw...spx?SKU=8058257
SILVY968 - 03-26-2008
xrad's recommendation is a good one. I use the same on all bolts into aluminum, plugs as well. A little goes a long way and it gets all over your hands and tools. The LOCTITE sticks are way less of a mess. I also have anti seize "silver stick" as well as sticks of red and blue loctite.
Here is the product line:
[attachment=5398:attachm
ent]
Cloud9...68 - 03-27-2008
Thanks, Brian. I didn't know Loctite comes in sticks. I'll look for it next time I need to buy some (already bought the 270 liquid).
Cloud9...68 - 03-29-2008
Well, I put the Permatex 80078 on my water pump bolts, then when I checked the manual for the torque specs, I noticed the manual recommends using Loctite 270 on the water pump bolts, which is a very high strength, "permanent" material. This seems like a strange recommendation on such small bolts, especially with a gasket in the picture. I went ahead and torqued them down with the Permatex, but before I put the belts back, what do you guys think about this? My inclination is to leave it like it is, since the anti-seize lubricant seems like a more logical material to use on this type of application than a high-strength Loctite. Thanks.
xrad - 03-29-2008
I have never been a fan of using loctite on aluminum threads......
Yeah, struct me as not the best idea, too.
xrad - 03-29-2008
from my latest engine build (Alfa- I know it's not 968, but application similar...):
Yep, that's the stuff. Nice shiny new bolt...
unknown4u - 03-30-2008
Or using copperpaste to keep the bolts going in aluminium. Not a good idea too.
xrad - 03-30-2008
agree w/unknown4u...aluminum for aluminum
