Wheel Offsets - Printable Version
+---- Forum: Wheels (https://968forums.com/forum/wheels)
+---- Thread: Wheel Offsets (/wheel-offsets--11411.html)
Wheel Offsets - TC17 - 04-17-2008
Hi
I am planning on buying some light weight race wheels for my CS which is now fully stripped / race prepared. I am currently running original 17" Cup 1's (Front ET65, Rear ET55) with 7mm shims / spacers. With the spacers fitted I assume I have changed the Offsets to ET58 Fr and ET48 rear...correct ?
I am planning on widening the track front and rear whilst maintaining the offset difference front to rear (10mm).
For racing purposes, what Offsets do you recommend whilst sticking with 17" wheels ?
My camber set up is:
Front: -4 deg
Rear: -2 deg
Any advice / opinions would be appreciated.
Tony
Wheel Offsets - Big Dave - 04-17-2008
[quote name='TC17' post='51015' date='Apr 17 2008, 10:03 PM']Hi
Front: -4 deg
Rear: -2 deg
Tony[/quote]
Hi Tony.
You can go to an ET of 50 or maybee a little less [ie et45] on the fronts....
And around the et 47-50 at the rears.
To achieve this youl either have to buy the spacers with the bolts built into them,, OR get a set of longer studs.OR a set of wheels with the et of 50ish....
What wheels are you thinking of getting.??
[quote name='Big Dave' post='51017' date='Apr 17 2008, 02:30 PM']Hi Tony.
What wheels are you thinking of getting.??[/quote]
Sent PM
