improve air flow - Printable Version
+--- Forum: REV IT UP (
https://968forums.com/forum/rev-it-up)
+---- Forum: Heavy Breathing (
https://968forums.com/forum/heavy-breathing)
+---- Thread: improve air flow (
/improve-air-flow.html)
improve air flow -
Lim Yong - 05-26-2008
Hi all,
Flash mentioned he moded to improve under car air flow. Flash, any one can explain the benefits?
Also, can we improve ait flow throgh radiator some how?
improve air flow -
94SilverCab - 05-26-2008
Do a search on Air Box Modification...you will find out more than you could ever imagine...
improve air flow -
flash - 05-26-2008
he's talking about the under car flow mods (belly pans and splitter and such)
to learn about the benefits, a good google search will explain it a lot more than i can here - or, you could take a look at the underside of just about any high end car these days - it's all about positive and negative air pressure zones
as for through the radiator, the splitter does a good job of focusing that air - the biggest problem challenge is cutting off extraneous air from getting into the engine bay and mucking up the negative air pressure zone - i've done quite a bit of work there too, and have come up with a set of pieces to facilitate that
fun stuff, but not likely something i'll be knocking off - no demand
improve air flow -
Hi Flash,
I for one is interested, or if you are willing to share your research, ideas... thanks
improve air flow -
flash - 05-26-2008
i'll think that over - i still have to gather some more empirical data on it before i am ready to release the stuff
