LED 3rd brakelight upgrade -
flash - 01-04-2008
remember to check with the laws in your state regarding what is and is not legal - some states have lighting inspections that are very specific
SILVY968 - 01-05-2008
[quote name='968gene' post='45255' date='Jan 4 2008, 06:14 AM']Brian, I may have missed this, have you located LEDs in red that are bright enough?[/quote]
Here is the link to the complete directions and parts from Dave's site (968engineering):
http://www.968engineering.com/968chmsl.html
It has complete DIY instructions with pictures of the final product.
LED info:
http://www.jameco.com/webapp/wcs/stores/se...roductId=197616
The seven LED's are ULTRA bright. Get 10 @ 18.4 cents each.
saxman - 01-05-2008
[quote name='SILVY968' post='45250' date='Jan 3 2008, 09:39 PM']The lens will be clear. It will be cast in polyester resin.
I do not have a vacuum chamber, so I'll try the "bombs away" method.
The guys at TAP tell me that if I pour at the edge of the mold that I should not get any bubbles.
If the bubbles end up forming and I do not like the look, I guess that I could always cloud-up the inside of the lens to hide them and defuse the light. It may end up that even with a bubble-free lens some clouding would be desirable to defuse the light and keep you from seeing the PCB, wires and LED's inside the housing.
Brian[/quote]
be sure you're using a clear casting resin and not just any old polyester resin
also, the act of simply mixing the resin and the catalyst together will cause bubbles... in school when we were doing any sort of casting, all of the resin was degassed before it ever touched the mold.
If you have an air compressor, you can pressure cast the parts to deal with the bubbles as well.
968gene - 01-05-2008
I did a quick search of the 'net to see if there were any Corvette owners out there that have tackled the 3rd brake light LED conversion. I'm guessing that the 968 3rd brake light originating with the Corvette is an urban legend. It appears that Chevrolet has had the 3rd brake light integrated with the bumper since the Vette returned in 1986 (via ASC). I noticed on the ASC web page that ASC also did the Buick Reatta in 1990. The Reatta 3rd light looks familiar. Does anyone have additional information? If the 968 light comes from the Reatta, there is less chance that there are custom LED conversions out there.
sasilverbullet - 01-05-2008
I built this myself - didn't take long. As long as you know how to solder it's an easy mod...
Just have to order the LED's...
[quote name='968gene' post='45279' date='Jan 5 2008, 06:56 AM']I did a quick search of the 'net to see if there were any Corvette owners out there that have tackled the 3rd brake light LED conversion. I'm guessing that the 968 3rd brake light originating with the Corvette is an urban legend. It appears that Chevrolet has had the 3rd brake light integrated with the bumper since the Vette returned in 1986 (via ASC). I noticed on the ASC web page that ASC also did the Buick Reatta in 1990. The Reatta 3rd light looks familiar. Does anyone have additional information? If the 968 light comes from the Reatta, there is less chance that there are custom LED conversions out there.[/quote]
The mod is one of the easiest electrical mods on the 968. All you need are simple tools that you can borrow or get from Radio Shack.
The part to pay attention to is that you are soldering in the LEDs in the correct direction. They have an "in" and an "out", if you will, and will not light up if soldered in the wrong way. I had a spare 12volt battery in the garage, so I tested the led placement before I installed it into the lens. Saved time as I screwed up 2 of the LEDs.
You can unsolder the wrong ones and turn them around and solder them right back in. Putting them in backwards does not damage them. If you look into the clear plastic body of the LED you will see that there is a difference in the shape of the metal pieces inside; figure out one and copy.
Even if you have never soldered, this project is very easy for a first-timer.
It will take you more time to remove and replace the assembly than to drill the holes and solder in the parts. Don't forget the resister. You need to get the exact value and wattage to avoid problems.
flash - 01-05-2008
it's definitely a GM part - a quick call to them would tell what cars came with it
anyone have the part # handy?
flash - 01-05-2008
not handy - gave the lens away, but i still have the metal piece up in the attic - i'll poke around up there and get it down as soon as the rain stops
housing
Porsche #941-631-911-00
GM# 16505865 2 E casting # 930939
lens
Porsche #941-631-261-10
GM# 16505868 casting # 1892273
flash - 01-05-2008
there are gm numbers in there too (at least there were on mine)
968gene - 01-06-2008
Thanks Brian. Google didn't turn up anything. Could this be a European GM part number?
SILVY968 - 01-06-2008
I could not find it either. The DOT on the lens says 86. In the old days the year was on the lens, so maybe it was originally made in 1986?
Anyway, I just modified the OEM lens by removing the pins and the tab and added a new slot in front of the old tab to hold the center of the PCB in it's new location.
The mold box is made and Monday will be the day that I'll pu the silicon rtv and cast the mold. I'll get the polyester resin and try the pour next week if the mold comes out OK.
flash - 01-06-2008
i'll try to dig mine out of the attic - the numbers listed above are the porsche numbers - there are other numbers that are GM numbers, at least in mine - mine even has the logo - i did this already once before, but managed to lose the research notes in one of the moves
[quote name='flash' post='45315' date='Jan 6 2008, 09:01 AM']i'll try to dig mine out of the attic - the numbers listed above are the porsche numbers - there are other numbers that are GM numbers, at least in mine - mine even has the logo - i did this already once before, but managed to lose the research notes in one of the moves[/quote]
housing
lens
GM# 16505868 casting # 1892273 ( has 86 on the lens, 1986, maybe? )
(with GM logo )
flash - 01-06-2008
sweet!
that saves me a trip into my attic
[quote name='flash' post='45300' date='Jan 5 2008, 06:02 PM']not handy - gave the lens away, but i still have the metal piece up in the attic - i'll poke around up there and get it down as soon as the rain stops[/quote]
Does this mean that you are running without it?
As mine is off now, getting ready to make the mold, I REALLY like the rear cab deck without it. Too bad I didn't think about it when I had the deck lid painted last year!
I'll just pretend that it is a safety issue and forget about how much cleaner it looks without it, rats!
I think 1986 was the first year of the mandate for a high mounted brake light. I've looked at internet pics of the Corvette, Cavalier, Sunbird, and Camaro. No luck.
flash - 01-06-2008
yes, i am running without it - have been for a couple of years
Anchorman - 01-06-2008
..or there's
