Air box modification - Printable Version
+---- Forum: Engine Management (
https://968forums.com/forum/engine-management)
+---- Thread: Air box modification (
/air-box-modification.html)
Kaj Hallstrom - 07-13-2017
OK, this this where I got confused. I did remove the snorkel and left the "Shroud" (front engine cover...right?) in place......Am I still confused?
MCL968 - 07-13-2017
That's exactly what you should have done.
Kaj Hallstrom - 07-14-2017
Thank You, now I am back with the program.......now to the chip....what's the story?
MCL968 - 07-14-2017
Talk to Pete, I like the stage 1 from rs barn. You need to get the number from your stock chip to get the right one from Pete.
Kim - 07-14-2017
Look at the forums section CHIPS AND SALSA
ds968 - 07-14-2017
Quote:Look at the forums section CHIPS AND SALSA
+ 1.
Incidentally, prior to the SC, when I had the air box mod, performance CHIP , and catback system , I used the " Speed 6 , racer-X " chip and had absolutely no problems with smog checks . In fact all the readings were indistinguishable from the pre-chipped era.
94SilverCab - 07-14-2017
Quote:Thank You, now I am back with the program.......now to the chip....what's the story?
Seriously...there are about 400 threads on this topic. Please do a search, read everything you can, and then, if it is even remotely possible that you have a question, go ahead and ask.
Refer to the ENTIRE SECTION called "Chips and Salsa"
Rap - 07-14-2017
What's the heat factor on the salsa?
ds968 - 07-14-2017
Quote:What's the heat factor on the salsa?
That depends on your dance ( salsa ) partner.
Uh...
Thanks I found the tread. There are a gazillion out there. Not always easy to find what what you are looking for.
Rap - 07-15-2017
Where's the thread for salsa partners with chips?
