Fuel pump issue - Printable Version
+---- Forum: Engine Management (https://968forums.com/forum/engine-management)
+---- Thread: Fuel pump issue (/fuel-pump-issue.html)
Fuel pump issue - DaveN - 06-24-2011
One would assume the stock fuel filter would catch any debris, not sure why and extra filter would make any difference?
The only advantage I could see is removing the stock one an putting in a clear one so you could see if there were any contaminants.
That's why I suggested a postmortem on the old filter. If there is no junk in there then the re-re of the gas tank might be a futile exercise.
Fuel pump issue - m-wilhelm - 06-24-2011
[quote name='DaveN' timestamp='1308943730' post='111720']
Gas goes from the tank to the pump to the filter, so the stock filter is after the pump. There is a fuel screen in the tank that should block most debris from getting out to the pump but it doesn't seem to be working for me. I replaced the in tank screen after the first pump and before the second. I found some black debris in the filter that looks like charcoal, so I need to check the tank next.
