GT Racing Hatch -
Cloud9...68 - 10-11-2013
Nice to hear the new hatch "glass" fits well. Another thing on my wish list...
GT Racing Hatch -
DaveN - 10-11-2013
Tks for that link Ryker. If it doesn't get snatched up by this thread starter I will try for it. I have 3 broken defrost lines and a big gouge in my hatch from the <acronym title='previous owner'>PO</acronym>. It has bee really hard to find a piece of glass close to BC.
GT Racing Hatch -
paulzebo - 10-11-2013
OK, here's how it went. The hatch arrived from GT Racing with the manufacture's sticker stating it was made by Five Star Race Car Bodies.
http://www.fivestarb...=product&id=485 The hatch fit very well needing only around 1/16" to be removed from the lower front radius on each side. This is easily done with a belt sander with a 120 grit belt.
I used two primers for the job. Dow Betaprime 5504G for any exposed metal and its equivalent for plastic parts Dow 5404A for the Polycarbonate panel. The 5404A has a similar container as the kits Mercedes markets, Smart Car Glass Plastic paint sealant kit.
I used vinyl electrical tape to mask a surround area around the polycarbonate. Vinyl tape because it holds a tight radius without distortion and seals better with the chemicals used in this primer. This keeps the primer from running under normal masking tape creating a dirty line. Scuff the area you are going to paint with 600 grit sandpaper until it is hazed. Don't worry, the scuff marks will be filled by the primer. Using a clean cloth containing denatured alcohol, move in one direction around the whole area to be painted. This will clean the area which was just scuffed up, removing any poly dust from the sanding operation.
Follow the instructions on the Dow Betaprime 5404A bottle making sure the shelf life has not expired and it is shaken thoroughly. Apply primer over the scuffed surface area in one direction. Wait two minutes and repeat until the area you want covered is blacked out. These primers contain carbon black, so they will block all UV and visible light. Adhesion is fantastic and you possibly could skip the next step of painting if you choose to do so. But since it's all taped off, I waited 10 minutes and then hit the area with a hair drier to make sure all the primer was completely dry.
Jerry Bickel Race Cars makes a black border spray paint specifically formulated for polycarbonate windows.
http://www.jerrybick...pray-paint.html One can is enough to border ten hatches, so don't over order as I did. Spray three light coats on the border area letting each dry between coats.
Wait a day for everything to dry thoroughly
Clean the hatch channel with alcohol, let dry and apply the Dow Betaprime 5504G to any exposed metal surfaces. Dow says this is a direct replacement for the 5404A but since I could not find any posts or articles which did, so, I choose the old 5404A rather than take the chance.
If I had to do it over again, I would have a glass shop assemble the hatch to the frame. The Dow 428Plus windshield urethane primerless adhesive is thick and tough to apply to the frame using a standard caulking gun. That said, it can be done. Here's the current result.
Now for the questions on weight by
Cloud9...68 . Installed in the frame, hatch assembly without trim and spoiler, weighs 21.5 pounds. It was light enough that when I put it back on the vehicle, I contemplated not using the old hatch struts. Until I put the spoiler back on. It added just enough weight that struts are necessary just for convenience but they are way too powerful. I'm looking at a replacement set from
http://www.autogassp...iversalpage.php with a lower rating.
MB968, Dubai944 and Ryker brought up scratch resistance, UV protection and heat rejection issues when using a polycarbonate hatch. I'm going to take the hatch off tomorrow and put on some Exterior Plexi 6 Mil Clear Anti-Graffiti Window Tinting Film from
http://www.windowtin...nting-Film.html This film is designed for polycarbonate windows, goes on the exterior of the window, has a 99% UV rejection and 23% heat rejection rating. When scratched up it can be removed and replacement film reinstalled. If heat transmission remains an issue, this tint can be removed and replaced with Exterior Plexi 2 Mil Silver 20% VLT Window Tinting Film which has a 82% heat rejection rating. I didn't want it due to differing state laws and its 20% Visible light transmission rating.
All said, practical application on a street vehicle is, not ideal. When the car is idling you can see the window slightly vibrating also. Such is not the case with glass. Maybe a vendor will make one out of 1/4" but your weight savings will be gone. Eventually the coupe owners may have to take this route as replacements get rare. Better to drive it with a vibrating hatch than not to drive it at all.
Oh, heard back from the insurance company today. They still cannot find a LKQ hatch so they are sending me a check for $6867.88 to buy a new one from Porsche. 968 512 929 00 here I come! <img src="/forum/images/smilies/968/EmoticonCar.gif" class="smilie" alt="" />
GT Racing Hatch -
ryker - 10-12-2013
No problem DaveN! I'm always looking around Craigslist when I get bored. Hwy, I'm actually in Seattle right now!
Paulzebo, $6867.88, wow! I would pocket the diff and purchase a Design 1 Racing supercharger with the difference between a new one and a used one!
GT Racing Hatch -
gbarrier - 10-12-2013
Quick hijack and I'll get out. If anyone buys a hatch for the glass I am interested in the hockey sticks, especially passengers side.
GT Racing Hatch -
Cloud9...68 - 10-12-2013
Nice work! You really seem to know what you're doing on what looks like a somewhat daunting task. Have you ever done anything like this before? Also, you spend a lot of time in your post describing painting something, but I'm not clear on what needs to be painted when replacing the hatch glass. Thanks.
GT Racing Hatch -
flash - 10-12-2013
what did you find the lexan to weigh versus the glass?
GT Racing Hatch -
paulzebo - 10-12-2013
Cloud9...68 To urethane polycarbonate into an opening, you first have to scuff up the surface and paint/primer it. If you do not, out gassing from the polycarbonate panel will cause an early delamination. Such is the purpose of painting a black 1-1.5" surround on the panels perimeter. The paint/primer seals the area which allows the urethane to stick to the metal frame while giving it a factory glass look. Out gassing is also the reason regular window tint does not do well on polycarbonate panels.
Flash I didn't have all the glass to weigh, but what I collected weighed in at 31.6 pounds. That's just glass. The hatch frame and Polycarbonate weighed in at 21.5 pounds without the spoiler or hockey sticks . It would be interesting if someone actually weighed a 944/968 hatch and glass so we could compare. My guess would be the Polycarbonate switch saved less than 15 pounds total. Keeping in mind this is 3/16" and not the racing 1/8" polycarbonate.
Now it's time to take it off and install the Plexi 6 Mil Clear Anti-Graffiti Window Tinting Film.
GT Racing Hatch -
flash - 10-12-2013
yeah - that sounds about right. i think the 1/8 thick unit only peeled off a bit less than 25#
GT Racing Hatch -
Yeah, that's about what I remember as well, maybe even less in terms of weight savings. It just isn't easy to take weight out of these cars, or any cars.
GT Racing Hatch -
flash - 10-12-2013
well..........it's pretty easy to get the first 150 or so lbs. after that, it gets tougher, and a LOT more expensive.
the best thing to do is go as light as you can on the tires and wheels. stay away from 18s. that one is a very common mistake i see a lot of the "experts" making. the tires are anywhere from 2 to 5 lbs heavier than the same width in a 17. the mass is at the outside too, which is a whole lot worse than at the hub. that basically costs you 1hp for each pound at each corner. it adds up fast. staying at 17s also allows you to go a bit smaller on outside diameter, which for a track car is great, as it gives you what is effectively free torque by lowering the final gear ratio.
fiberglass body panels can save a total of about 75lbs if you change fenders, doors, and go to a pinned hood. carbon fiber is really not much lighter. it will cost you about $3k though to do it.
back on topic
i hope the lexan hatch work out. having seen what it looks like after a couple of years of use, i wonder how one would feel down the road. at least with 3/16 the warping issue will be reduced.
