Threads: 45
Check the 8 way round Pin block connector is plugged in, even if the drive cables are broken you should hear the motors run
And the fuses of course, but I bet you have done that already
(This post was last modified: 04-04-2015, 06:03 PM by
Waylander.)
Threads: 13
You might have to take apart the switch and clean it up. There are tiny ball bearings in there that make the connection when you press the buttons. I have 4 way adjustable on each seat and only 2 out of the 8 worked when I got the car. Took the switches apart, cleaned the connections and put everything back together...everything works like new now. Took an afternoon. Not a hard job but those tiny ball bearings and the srings they ride on and somewhat annoying to try and put back together...take your time and don't lose anything.
There are step by steps around the help if you search.
1972 914 2.0 Signal Orange
1992 968 Coupe Polar Silver
1998 Civic (DD commute beater)
"Life is too short to not drive a Porsche daily"
