03-25-2015, 10:40 PM
I have been having battery issues with Porsche OEM batteries.
I was having a drop in charging voltage and replaced the voltage regulator and while it was out I ordered OEM battery cables to replace the 20 year old originals - just in case.
The car ran fine, and voltage was back where it should be in the 14.5 range...
then the car sat for a couple weeks while I was traveling and it was dead. It only had power enough to run dash lights.
I checked the voltage with a meter at the battery and it was around 12 volts. Not enough to start it.
I charged the battery, then tried again, but it would not even turn on dash lights. The charger said my battery had a dead short.
I took the battery to my mechanic, thinking Porsche would warranty replace or at least prorate a new battery since it was less than two years old. After 4 days of getting no where - we found out what the hang up is.
Porsche says you have to drive the car a minimum of 700 miles a month or the car is considered "in storage" and they will not compensate you in any way for a battery. My mileage for the two years is 4000 and works out to 166 miles a month.
My mechanic was able to recharge the battery, but no where near "new full" so I am stuck with basically a dead battery. He stated that the battery model Porsche selected for the 968 was just barely enough cca to get the job done and nothing more - which I think he said was just over 300.
I will be putting in a different battery with over 600 cca's so with any luck I will not have to deal with this again.
I do not recommend Porsche OEM batteries.
