Threads: 15
+1 on West End in Gardena for alignments. I will never go anywhere else again!
As for 968 savvy mechanics in our area, I haven't had tons of success. Tried Pristine Porsche - a little independent shop in downtown HB - they installed a balance shaft roller incorrectly and the belt was rubbing on something it wasn't supposed to and shredding. Had to be redone. They're primarily a 911 shop. They're great guys, but I can't recommend them for the 968.
I'm thinking of trying Einmalig, also in HB, to fix a large electrical issue (more of a disaster, really). They do restoration work on older Porsches and said they could handle it. Will report in if they successfully get my car back on the road!
-Austin
'94 Black/Tan Coupe
(This post was last modified: 10-03-2013, 01:34 PM by
bombfactory.)
Threads: 167
Please post the final cost from the shop you select, I'm guessing less than half.
Threads: 77
There is a good shop in Anaheim, probably one of the best around. He is a little meticulous though, so you might pay a little extra for that.
(This post was last modified: 10-03-2013, 04:55 PM by
banditsc.)
Threads: 15
Which shop is that, Flash? Steve's on Lincoln? They did my <acronym title='pre purchase inspection'>PPI</acronym>.
-Austin
'94 Black/Tan Coupe
(This post was last modified: 10-03-2013, 07:28 PM by
bombfactory.)
Threads: 63
[quote name='txn5060' timestamp='1380778454' post='150202']
My 1993 968 Cabriolet Slate Metallic has been my weekend car for the past 10yrs and has never failed me. Still Starts and runs strong. Came in for a checkup to a local SOCAL Porsche dealer to inspect an coolant leak and power steering fluid leak. 2 days of a full inspection report.
Cost breakdown
Replace upper and lower hoses for power steering $775
Replace new radiator and hoses $1367
Replace motor mounts $1999
Rear Main Seal? $1670
Oil Pan re-seal $990
Control arm $1065
4 wheel alignment $299
Front sway bar bushing $294
I'm at crossroads. I might have to depart my beloved 968.
txn5060,
IMHO,, the only part of that job with a reasonable price is the alignment. You could do between 2 & 3 cars with new motormounts for $1,999. I recommend that you don't use aftermarket motor mounts. You don't want to do that job twice!
SOLD! 1992 - 968
