New vibratoin/rattle
Recently I've started getting a vibration but it only happens when i let off the clutch from a start
then it goes away until 2200 rpm and then it goes away again. its the worst when i hold it right at 2200
or when i decelerate past that rpm.
I suspected the belts because it sounds like a plastic rattle but its bad enough that i feel it everywhere
petal,shifter etc.
checked the belts and all seems fine could this be the cluch? when i'm under the hood and pull
the throttle i can't hear or feel it but when i get into the seat i can. cant think of anything that
would rattle around a certain rpm and not all the time
HELP!
93 midnight blue cab
03 kawasaki zx6rr
03 k2500 duramax
83 944
66 volkswagon squareback
Could be a lot of things, but I'd suspect the clutch/flywheel assembly myself...
My car had a lightweight racing flywheel in it when I bought it, and it used to make a lot of noise around those rpm's. Too much clatter for a DD <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Does it make the same noise if the car is stationery and reving through 2200rpm? What about if it's stationery and you hold the clutch pedal in while revving it?
The other vibe that might fit is the driveshaft bearings in the tourque tube. How many miles on the car?
hth.
Michael
1994 968CS M030 White
2014 BMW i3 Silver
[quote name='au968' post='28723' date='Dec 4 2006, 08:28 PM']Could be a lot of things, but I'd suspect the clutch/flywheel assembly myself...
hth.
Michael[/quote]
The car has 95k and yes it does it when its stationary. pressing the cluch doesn't
seem to matter. although the pedal feels a bit notchy when running and smooth when
the engine's off.
It doesn't do it when its cold, but gets worse as it warms up.
Planning a clutch change anyway is this a good time to change the drive shaft bearing?
Thanks for the help.
03 kawasaki zx6rr
03 k2500 duramax
83 944
drive shaft bearing will require dropping the transaxle, and likely a couple of days down time - it requires a long ram press to change it - most people i know send it to 928 international to be done - roughly 500 bucks for that job alone
i recommend nailing down the noise before diving headlong into this - go buy a stethoscope - very cheap at sears
being a unibody car, vibrations and rattles move around a lot - the torque tube doesn't help either - that direct link makes it tough to track down - it could be as simple as a heat sheild, or as bad as a fragged DMF
be patient - try as many combinations of conditions as possible to help find it
Thanks fo the advice <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> I think I may have narrowed it down, the timing belt was loose ,seems
like the tentioner may be bad
I was able to put a wrench on the pivot bolt and tighten it back up, do these go bad?
Just received my new pulleys and will change tonight along with checking out the tentioner.
lol. Hope this is it <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
03 kawasaki zx6rr
03 k2500 duramax
83 944
cool - so it looks like the plastic sound may have indeed been from plastic contact
yes, those tensioners can and do go bad
double and triple check your pulley orientation to insure proper timing
good luck
lol. So i've learned my lesson again!!!!!! Allways check the obvious, crawled under the car
with a 10 and 13 and started checking everything, turns out that the upper rear alternater
bolt was almost about to fall out and the dust cover on the bell hausing was loose.
The vib/rattle is gone and it was a cheep fix. So if you get a chance!! crawl under your car and
check your nuts <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Thanks for the advice i've learned a few new things to check next time <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" />
03 kawasaki zx6rr
03 k2500 duramax
83 944
ok - now that you've found those things, make sure you check the tension on those belts
this is a common problem on the alternator - it often leads to broken mounting ears though - people try adjusting the alternator and power steering belts and invariably do it somehow wrong
either they fail to loosen the mounting bolts first before adjusting, or they forget to tighten them back up again afterward
good on ya though
[quote name='flash' post='28808' date='Dec 6 2006, 06:22 PM']ok - now that you've found those things, make sure you check the tension on those belts
good on ya though[/quote]
Ya That sounds like a likely scenario I've only owned the car for about 4 months and have no idea
at all what has been to it. Thaught i did a pretty therough job of looking it over but obviously
I haven't , I'm still learning my car <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Ps Don't be afraid to take it apart and put it back together but I can't figure out why i allways
have bolts left over <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
03 kawasaki zx6rr
03 k2500 duramax
83 944
Last Post by MLB
05-29-2014, 06:17 PM
09-12-2012, 01:31 PM
Last Post by xrad
06-11-2009, 08:45 AM
