New Member in California
I'm here to help my friend with his recently inherited 1993 968.  It's in beautiful cosmetic condition, with a handful of hopefully-minor problems from sitting in covered storage for a half decade.
Welcome,
Hope we can help get that car back on the road.
Regards,
It looks generally very good, but with points of white corrosion inside the engine compartment that suggests half exposed storage under a cover was only partial protection.
It runs well enough to move it, but with poor drivability.  It had 15-20 minutes of driving, and was reportedly on the verge of not making it up steep hills.
Right now the obvious problems are:
Idles OK, but has no power.  This is probably a spark problem. I pulled the TPS, because it is also a suspect and is easier.  It was initially quite electrically noisy, but there aren't any repeatable dead spots so I hope that it will self-clean.
I'll check out the distributor cap, wires and spark plug wells next.  I'm pretty cautious about the visible corrosion -- I don't want to break clips or snap off fasteners that I didn't actually need to touch.
The cam position sensor behind the distributor cap has a bad connector shell.  Disturbingly bad -- I've never seen one that just crumbled.  I have a spare Junior Power Timer 3 pin shell that I hope has the right keying to work.  The mating side (female pin, with spring clip) is much better condition, even though it presumably saw the same conditions.
Headlights work only with push-to-flash-high, and enough other lights are out that I'm not suspecting bulbs.  Is the headlight switch a known weak point?
Before you start the car again...please change the Timing Belt and Balance Shaft belt. Age is an issue, and if they snap the the valves clash!!!
Quote:Before you start the car again...please change the Timing Belt and Balance Shaft belt. Age is an issue, and if they snap the the valves clash!!!
+ 1 .
Hi DBecker and Friend and welcome to the forum.   Me and my ‘93 Cab live just up the road in Oakland.   As mentioned above, you don’t want to bend the valves.  It’s expensive.   Unfortunately, I know as I had some rats get some wood stuck where it caused my chain to jump, resulting in the dreaded bent valves.
Bill
Welcome
Last Post by stv951
04-30-2026, 04:02 PM
Last Post by Mike4749
04-23-2026, 05:35 AM
04-20-2026, 08:27 AM
