04-14-2006, 03:24 AM
okay, so I am still trying to put the fix on my 6000-rpm cutoff issue.
to recap, after 6 minutes of normal 6800-rpm cutoff the car begins cutting off at 6000 rpm. This is the same behavior Dave G. helped located in the manual - manual says it's due to a fault in the ECU. (*sniff* . . . come back Dave. . .)
I have done the following (most of which needed to be done anyways on my 80K car)
new o2 sensor
new plugs (bosch copper)
tank of 100 octane
disconnect the battery for 10 mins
blink test (shows 1-5 'no fault')
next step is to examine the ECU as many have recommended. Get the part number, confirm it's a stock chip. Some local 968ers have also offered to do an ECU swap to try and isolate teh problem.
I am wondering though -
Why don't I just put in a perf chip and see if that shakes the demon loose. I mean, i'm going to chip the car anyways. If it doesn't work then I've only lost time. If it works I've fixed the problem and done the chip also.
I know it's not strict troubleshooting but honestly if it fixes the problem, I don't care.
thoughts?
new o2 sensor
tank of 100 octane
thoughts?
