i finally got around to putting this DIY together - many want the delrin bushings, but are concerned about noise - this modification addresses that, and more
i do not recommend delrin bushings for a commuter car, or one which sees less than frequent close inspection - also, they are much harsher when it comes to impact transmitted to the steering wheel from bumps in the road - to be clear, this is a race component that must be kept relatively clean
if you have leaks, this modification should not be done until they are resolved - the fluids will deteriorate the grease, and wear out the bushings
all that being said, if you take care of them, these bushings will really improve handling
here it is:
www.968forums.com
