Saratoga Glass sunroof
I managed to find one of the last run of Saratoga glass sunroofs and purchased it a few months ago.   Just now got sunroof gears fixed/adjusted correctly (again) so took some pictures of the finished install.   Makes the car feel a LOT different inside - more "open" is the best way to describe it.    I also do a "double take" every time I see the car in my garage because the interior is so much more visible thru windshield due to garage light coming thru the sunroof.  Quality overall seems to be good - I did have a problem with one of the latches, but seller sent replacement hardware quickly and it was an easy fix.
(excuse my messy garage!)
Well done, looks great !!
Looks great. Your seats look incredible. Did you have them redone?
Quote:. Your seats look incredible. Did you have them redone?
They do look brand new !   I’m going to guess they have been redone only because of the small “folds” lines at the bottom of the headrest where it meets the top of the back insert piece.   The factory seats have the leather heat shrunk and those lines do not exist, nor can they form with time and wear.  This looks nicely customized hand work.
Thanks on the seat compliments.   A previous owner had the front seat inserts/insert surrounds only replaced sometime after 2014.    Back seats are still original - the replacement front seat inserts are slightly softer leather and are also a slightly lighter shade compared to the original, but a pretty close match.  If you look at the seat pics you can tell the slight difference between the inserts and the material on the side of the seat (which I believe to still be original).
I love my roof, best thing I have ever bought for it
Nice update, looks good and gives more light to the cabin.
If anyone is on the market for a Saratoga roof as shown on my car in this thread - this seller appears to have some available - https://www.feslerusa.com/products/porsc...ersion-oem
I have no affiliation with this seller, but figured I'd pass the info along in case anyone is looking for one.
