exactly the wrong thing - i am trying to PREVENT getting the weight to the front, and keep it on the rear where it belongs
brake lockup is due entirely to an upset in frictional forces between the tire contact and the rotor/pad - in a perfect scenario the frictional resistance of the tire equals that of the brake, and the wheel slows down evenly - add too much weight, and while you don't get lockup, you do get overheat, and you lose a lot of the braking capability due to the other end not grabbing - too little weight, and you get lockup - balance is everything - it's not as simple as mere hydraulic pressure shift - the frictional surfaces of the brakes, as well as the tires need to be balanced too
increasing the compression will slow down the transfer, as will the other things i listed
far too often i see people trying to increase front braking, which only results in out of control braking, and loss of speed in turns - it also frequently results in longer braking distances - if you get the rear brakes to work properly, they do more of the work, and this balances the car going into a turn
the idea is to set up the braking so that there is less rear to front weight transfer - this allows you to stay on throttle longer, which means faster entry and exit
in a perfect world, all 4 wheels would slow at the same rate, with the same friction, and the suspension would actively resist rear to front weight transfer, while allowing downward transfer equal on all 4 - we can't do that though (yet)
www.968forums.com
