Threads: 35
Trying to do DIY repair (add refrigerant) to a/c, but fitting doesn't want to attach. Am I in the wrong spot? Or, do 968s have a non- standard fitting?
Greg
'92 cab. Guards Red/Black.
Threads: 17
That is the high pressure port .
The low pressure port is on top off the compressor down below , i think you can not get to that port from te top , part of the lower platic belly pan needs to be removed if i remember correct .
volvo V70D5 Black
Porsche 968 amethyst
Threads: 35
Once I actually locate it, is it a standard fitting?
Greg
Threads: 35
My mechanic added some several years ago after checking for leaks. It stayed for a long time. I do have some cooling, just not enough.
Greg
Threads: 35
I probably do have a leak, but a pretty slow one.
Greg
Threads: 35
My mechanic is an hour away, so if I can do DIY on something that seems "simple", I'd rather do that. Had done it successfully on one of my other cars. The aerosol recharge can has a pressure gauge inline on the hose from the can to the fitting. It's probably not super accurate, but may be good enough to at least get me some cold(er) air.
Greg
Threads: 35
Still trying to decide if I want to attempt this myself, but remain unclear on location of port. On the PET Katalog diagram (illustration 813-15), what part # is it? Revealing my ignorance; is the A/C compressor on the passenger side (US) down low? I'd like to at least see what I'm up against in terms of obstructions and skinned knuckles to gain access.
I still have bad memories of changing the knock sensors...
Greg
Threads: 51
Compressor is on the drivers side low. Post is right off the body of the compressor. It has a protective plastic cap over it. If the A/C has been converted it will have a screw on adapter over the old fitting to mate up with the new cans of refrigerant. On our cars if the gas gets too low there is a pressure switch that keeps the compressor from coming on. I have had that happen on my 944S and just added a small can of 134a to it and watched the compressor come back to life. I never used a gauge but I was afraid to go beyond one can because of the lack of the gauge. I have had good results from the unit as far as cooling goes from topping off with one can.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 35
My system is 134a, so I should be able to charge once I find the port. Probably won't get to it until the weekend. Thanks for the help.
Greg
Threads: 35
Once I actually put eyes on the port, i decided to give it a shot. Put freon in until it didn't seem to be taking any more. Didn't quite make it into the green range on the gauge, but there was cold air coming out the vents, so it is at least a temporary improvement. If the charge doesn't hold, I'll take it to a professional.
Greg
Threads: 35
I took the belly pan off, but still had to take off the vertical shield behind the wheel, so MLB's approach may be a good way to go. Lots of crawling around on the garage floor, which I didn't enjoy, but needed to happen to get the job done.
Greg
