08-29-2005, 05:11 AM
Flash was good enough to put me on the right track to get the part numbers for all the little rubber bits and pieces that are needed if you are repainting your car (which I am). Thought these might be helpful to someone out there and they are a PIA to find (i;m checking around for best prices, probably will wind up with Pelican or Sunset Imports -- will advise:
Outside Mirror Base Gasket, Left, OEM: 944-731-247-00
Outside Mirror Base Gasket, Right, OEM: 944-731-248-00
Hood Badge Seal, OEM: 901-559-215-20
Outer Door Handle Seal, Small, Left, OEM: 944-537-621-00
Outer Door Handle Seal, Small, Right, OEM: 944-537-622-00
Outer Door Handle Seal, Large, Left, OEM: 944-537-631-00
Outer Door Handle Seal, Large, Right, OEM: 944-537-632-00
Lower Apron Seal OEM: 944.505.523.00
RIGHT BUMPER/FENDER GASKET OEM: 944.505.532.00.01C
LEFT BUMPER/FENDER GASKET OEM: 944.505.531.00.01C
RIGHT ROCKER GASKET OEM: 944.559.272.00.01C
LEFT ROCKER GASKET OEM: 944.559.271.00.01C
RIGHT ROCKER MOLDING GASKET OEM: 944.559.274.00.01C
LEFT ROCKER MOLDING GASKET OEM: 944.559.273.00.01C
REAR BUMPER COVER GASKET OEM: 944.505.283.01
