10-06-2005, 05:32 PM
In my quest to get the 968RS running properly many weird issues have cropped up.
A first the car was running lean. When it was tuned on the dyno to fix that it would run well for about three laps and then start breaking up. It seemed electrical as it only happened when car was warmed up and I started to drive hard. On the dyno it would do several pulls without any problem. Hum!!! I finally found a one way valve on the fuel cell that was restricted and reducing the fuel flow and eventually starving it enough to cause the misfires. after fixing that and rewiring the fuel pumps the fuel mixture is way too rich. Like 9.8 to 1, and it still runs ok just not a ton of power. i had it back to the dyne to lean out and finally make some real power. At least thats what I hoped. As we started to do dyne pulls at leaner fuel mixtures and getting more power it started to cut out again. and I know we are getting plenty of fuel and the venting is fine. new problem!!!!
We believe the fuel is airating when it is getting returned to the holding tank.
I though I would show you a picture to show you what I'm dealing with.
I may take some of the stuff off and simplify but that's a lot of plumbing I don't really want to do.
In the picture:
Pump 1 (under the two gold transfer pumps) and pump 2 visible
In the picture:
