Hello from Bulgaria
Well, unfortunately the 1994 cab 968 --which I bought just about a year ago -- is parked near my alter-home in Sweetwater, Texas. I won't get back there until March. Hopefully, the car will ready to start up when I get there. It needs some cosmetic TLC.
Cheers,
Mike
Welcome!
Look forward to hearing from you once you are reunited with your 968. \
Curious: how long has it been "sitting"?
Welcome. Absence makes a heart grow fonder!
Welcome! I hope the trickle charger kept it alive :-)
My '94 cab has been sitting since early November. I typically get back to TX in the spring and fall. So, this time it will have been sitting unkept for about 4 1/2 months, about the same as last time, which was from early May to mid-September. As before, I disattached the battery cable, then put the cover on and that was it. Last time the car started up quite readily after I had re-attached the battery. Hopefully the same will be the case this time. I know I should probably put it up on blocks -- but, well, I tell myself it will be ok as it is parked on top of a bed of smooth pebbles in a covered area, so the tires at least are kept dry.
Last Post by 968csc
06-14-2026, 09:47 PM
Last Post by Mike4749
04-20-2026, 08:37 AM
04-20-2026, 08:30 AM
Last Post by Petethepug
06-27-2025, 09:01 PM
05-28-2025, 06:45 AM
