Is this my low pressure a/c port?
Only ‘ 92s used R 12 ?    Mine is a ‘94 , so does that mean that it has a factory set up for 134 A,  but they still used the hoses from the R 12 system ?
Correct , i have a 92 and worked on many other 968  , the filter  dryer in the sytem is different model , the rest hoses etc , it is all the same .
I put in a new condensor and rebuild the pump and put the new(different) oil in ,  when i retrofitted it to r134a and it workes fine ever since .
Just a 10% less r134a in the sytem , if i remeber correct .
Got it, thanks !
Last Post by wiseman
08-21-2010, 08:45 AM
Last Post by mitch968
05-08-2006, 01:22 AM
