Headlight Bulb Replacement for Street Cars
I just did a search on headlight bulbs and nothing came up, so I was wondering what bulb is the brightness for nighttime use in a street 968 vehicle is recommended.
I put in PIAA bulbs in 2010 and just called PIAA to find out if their bulbs have improved. They have a new bulb called extreme white #9004 which they say is the brightest one they sell which would fit in the 968's, and may be approximately 50% brighter than my old bulb.
What do you experts think?
The key here is "the brightest one that can be legally used." Many, including myself, choose an off-road bulb. Osram Bilux H4 70/65W is my choice with no problems.
Careful with the load, the wiring may not support the wattage. There is a link somewhere in here that discusses bulbs, and specifically headlight bulbs.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Wiring and draw are a consideration which is what PIAA stands for in all their bulbs, as they draw the same current with more light output so they claim. I could not find the link in the forum which is why I started this thread.
Use the little gear thingy at the top. As Flash says, search is your friend.
Here is one of the links I found searching for "Headlight bulbs":
http://www.968forums.com/topic/13399-bes...ntry145688
There are several others, some also list the best dash bulbs, which is very helpful.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Last Post by snova
06-27-2020, 07:35 PM
Last Post by 968JPN
07-18-2017, 10:25 AM
