Threads: 42
thanks...you think Lowe's or Home depot carries them? Would an autoparts store have them? stock bolts are 1-1/4, I need 1-1/2.
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
Well, appears you can't install both the harness bar and the shoulder belt together. The angle mount for the harness bar pushes down on the seat belt mount and prevents it from swiveling.
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
Got the harness installed. In my local PCA, it is illegal to attach the harness directly to a harness bar, can only be used as a guide. I hooked the two shoulder belts to the lower rear seat belt points (see pic) and ran them over the harness bar. harness bar is attached to the two front upper seat belt points (used weltmeister bar). I hooked the lap belts to the regular side seat belt mounts. I hooked up the sub belts by drilling through the floor pan, using eye bolts. I located them about 2 inches forward of the side seat belt mounts and spread them about 4" apart. Used a 3 inch washer underneath to secure eye bolts to floor pan, loaded it up with silicon to keep it weather proof. Pretty easy job, minor hitch was that the left rear seat belt bolt was pretty long and I had some trouble getting it back in as there is a 1" spacer to go through before the bolt seats.
Fun weekend, took the door panel apart to fix my driver-side window, put this harness in and put the track tires on. Looking forward to the first track event of the season this coming Saturday/Sunday at NJ Motorsports Park on the Thunderbolt track!!!
2005 Acura RL
2004 Toyota Sequoia
Threads: 42
Are you talking about the drop from the harness bar down to the rear seats belt points? if that is too steep, where else can I mount it? I thought the guide bar makes it doable. If that is the case, what is the point of the guide bar?
2005 Acura RL
2004 Toyota Sequoia
(This post was last modified: 03-13-2011, 09:43 PM by
rl968.)
